It is currently Fri Nov 13, 2026 10:58 pm
 Post subject: Stove Choke - Weber Carb
PostPosted: Thu Aug 07, 2003 8:18 am
I'm thinking about getting the ProLineFuel.com Weber Carb setup.
What happens to my Stove Choke (that's what it's called, right?)??
I have a 63 Valiant with a 170 and the 3 on the tree..
Joe
My 63 Valiant
http://www.readersrides.com/rides/class ... aliant.htm
<img src="http://www.readersrides.com/slant6-02.gif"/>
PostPosted: Thu Aug 07, 2003 12:02 pm
Choke stove becomes a non-issue as these Webers are provided with electric chokes, just wire to a 12v ignition on source (ballast resistor is a good spot).....Dave
PostPosted: Fri Aug 08, 2003 7:07 am
So the hole just stays open?
My 63 Valiant
PostPosted: Fri Aug 08, 2003 10:20 am
I suppose you could install the manifold housing without the guts or linkage for appearances sake, personally wouldn't bother and just leave the well open. BTW checked out your site, been awhile since i've seen on of these dropped and its a good look on these valiants. Which Proline set up are you considering?...Dave 8)
Troops on the battlefield have a far better view of the battle then the generals who lead them
PostPosted: Fri Aug 08, 2003 10:31 am
If your exhaust manifold is the later type with the stamped "cup" insert, you will have to bolt the assemble in place to prevent an exhaust leak.
For the other types of "casted-in pocket" manifolds, you can leave the area open.
PostPosted: Fri Aug 08, 2003 1:01 pm
He has a kit that get's you an adapter from a single barrel to the double.. You get the adapter, the weber double & an air cleaner for $355.
- I'm looking forward to the eletric choke... I'm hoping that it helps that it helps cold starts.
Joe
PostPosted: Fri Aug 08, 2003 1:14 pm
Joe
- thanks for checking the site... www.readersrides.com is my site. I'll have a mopar section up soon... hint.. hint...
My 63 Valiant
PostPosted: Fri Aug 08, 2003 1:53 pm
I'm leaning towrds the single for now also, except will use with a 2 barrel manifold that has had some work done to it....Dave 8)
PostPosted: Fri Aug 08, 2003 2:12 pm
When I was running the original 1 barrel and intake, I could never get the choke cup to seal on the manifold untill amazingly I found some original asbestos gaskets at a few dealers. I wonder what it would sound like, assuming the engine would run, with the choke stove removed opening up the exhaust.
PostPosted: Fri Aug 08, 2003 3:03 pm
Too cool-tri exhaust manifold. I'll let you build the first one...Dave
PostPosted: Fri Aug 08, 2003 7:10 pm
Probably like my 63 - I run a straight pipe... no muffler, just 1 1/2" pipe straight back... sounds pretty mean.
Joe
My 63 Valiant
PostPosted: Sat Aug 09, 2003 10:23 am
You ought to hear it when you run 2in. all the way back with a 18in. glasspak! .....Dave
PostPosted: Sat Aug 09, 2003 12:13 pm
How about dual 2 1/4 inch glass packs with driver side outlets, running off headers. LOUD.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 3 guests
