It is currently Fri Nov 20, 2026 10:14 am
 Post subject: What year?
PostPosted: Wed Nov 03, 2010 7:55 pm
What year did the head change so you have to remove it to get the lifter out??? I have an 80.
Daily 1980 Dodge Aspen 2dr leaned power, 904, 600 holley 4V w/offy intake, dual headered
PostPosted: Wed Nov 03, 2010 8:08 pm
The head changed in '75. The loss of spark plug tubes meat the loss of easy access to the lifters.
PostPosted: Wed Nov 03, 2010 10:56 pm
Not so, you should be able to remove the lifters without removing the head with a '80 or later head.
PostPosted: Thu Nov 04, 2010 12:03 am
6 Pack Dart
Kevin that isn't going to work the lifters are much larger than the push rod holes in the head. :roll: :tsk: :lol:
Richard
PostPosted: Thu Nov 04, 2010 8:11 am
I believe '81 was the latest (hydro) head with larger pushrod holes, just bigger than lifters. '76-81 was one with small pushrod holes and no drool tubes.
PostPosted: Fri Nov 05, 2010 11:33 pm
I have an '80 head seating on the floor that you can slip the lifters thru. The '79 head that is currently on my engine you can not.
