It is currently Fri Nov 20, 2026 10:18 am
 Post subject: What year?
PostPosted: Wed Nov 03, 2010 7:55 pm
What year did the head change so you have to remove it to get the lifter out??? I have an 80.
Daily 1980 Dodge Aspen 2dr leaned power, 904, 600 holley 4V w/offy intake, dual headered
PostPosted: Wed Nov 03, 2010 8:08 pm
The head changed in '75. The loss of spark plug tubes meat the loss of easy access to the lifters.
PostPosted: Wed Nov 03, 2010 10:56 pm
Not so, you should be able to remove the lifters without removing the head with a '80 or later head.
PostPosted: Thu Nov 04, 2010 12:03 am
6 Pack Dart
Kevin that isn't going to work the lifters are much larger than the push rod holes in the head. :roll: :tsk: :lol:
Richard
PostPosted: Thu Nov 04, 2010 8:11 am
I believe '81 was the latest (hydro) head with larger pushrod holes, just bigger than lifters. '76-81 was one with small pushrod holes and no drool tubes.
PostPosted: Fri Nov 05, 2010 11:33 pm
I have an '80 head seating on the floor that you can slip the lifters thru. The '79 head that is currently on my engine you can not.
Users browsing this forum: Google [Bot] and 12 guests
