It is currently Fri Jul 17, 2026 10:07 pm
Post new topic  Reply to topic  [ 1356 posts ]  Go to page Previous 112 13 14 15 1691 Next
PostPosted: Fri Jul 23, 2010 10:12 am
Wow thats rockin!
Nice and consistent.
Thanks guys,
Yeah Sandy Ruster is doing better than the last time you saw it, when we were picking our brains about white oil :roll: :shock: :lol:
PostPosted: Fri Jul 23, 2010 12:21 pm
Congrats, Greg. OK, maybe I won't catch you again at Hagerstown.
PostPosted: Fri Jul 23, 2010 1:10 pm
Greg, good for you! You must have thrashed pretty good to get that all done in time for Wilkesboro! I am looking forward to actually seeing you driving at Hagerstown, instead of holding an umbrella over you in the pits.
Brian
Flyin' Brian
"Sixy Beast"
PostPosted: Fri Jul 23, 2010 4:42 pm
Brian
Dont Worry Brian, You can still hold the umbrella for me - Hopefully it will be for shade this time!!
HA HA :shock: :D 8)
 Post subject: Tnt 7-29-10
PostPosted: Fri Jul 30, 2010 6:59 am
Here are the 4 runs I made:
Run 1:
1.993 60'
8.71@80.65 1/8
13.60@111.38 1/4
Run 2:
2.0701 60'
8.70@81.46 1/8
13.55@101.06 1/4
Run 3:
1.9309 60'
8.51@81.71 1/8
13.36@100.76 1/4
See you at hagerstown for the good Air!
PostPosted: Fri Jul 30, 2010 9:03 am
Greg,
You are getting into good territory there! Looks like the 12s might be in striking distance... See you several hours.
 Post subject: Hagerstown TNT 7-30-10
PostPosted: Fri Jul 30, 2010 10:19 pm
Ran a Best 1.90 60'
and another 101 Mph Pass
and a 13.26 Et.
Changed to some richer jets to the secondary Circuit to compensate for the good air.
PostPosted: Sun Oct 31, 2010 3:10 pm
Well Alot Has happened since the last post in July.
I won My first Slant Six Race in Hagerstown Md with Ruster in it's Rookie Season.
I did hit a couple of TNT's around here since then - Tried a bigger carb and really nothing came of it.. Except for a better idle. So the old 500 CFM carb will be going back on and a Grear Change from 4.30 to 4.56.
I also managed to break a flexplate / Torque converter.
CARNAGE PICS BELOW! Nothing serious happened except for a bunch of rattling at idle like a #6 rod bearing was toasted.
Thankfully that was not the case.
Two welding points came off the Converter (see Pics) and one leg of the flexplate broke leaving one leg / bolt / mount driving the whole converter.
More updates coming soon!
Ruster Is going on a serious diet this winter too!!!
PostPosted: Tue Nov 02, 2010 9:00 am
I would send back to Midwest and have them fix the mounting points. Looks like cold weld spots.
PostPosted: Tue Nov 02, 2010 2:21 pm
That new flex plate looks good and strong hopefully you won't run into this problem again. :)
Lookin good and putting up some real nice times
Kev
PostPosted: Wed Nov 03, 2010 10:29 am
Why yes, I believe that is the nicest '68 Valiant I have ever seen.... :P
PostPosted: Wed Nov 03, 2010 2:45 pm
:P :P :P
Correction!
Soon to be under 2575# nice 68 Valiant SIR!
PostPosted: Sat Nov 13, 2010 12:46 pm
Well I got all the bugs worked out of the converter and flexplate on paper and in theory - I will have to wait until I get all this stuff put back into the car to really try it all out.
The TCI Flexplate is for an LA engine / 904 combo - Also it uses 7/16" sized bolts to mount a non - stock type converter - which I dont have. So I found some M6 Metric washers that were a few thousandths smaller than the flexplate to converter holes and welded them in to get the correct sizing there.
Also the V-8 flexplate has one bolt hole about 1/2" off where it would need to be to bolt up to a slant crankshaft. So I drilled and welded to fix that all up. Now I have A SFI Slant 6 flexplate (Kinda) with modifications.
Pics below.
PostPosted: Mon Nov 15, 2010 2:10 pm
Thats the way to make things fit nice job interested to see the car back in action.
Kev
PostPosted: Fri Nov 26, 2010 4:33 pm
Ruster is going on a Diet in a big way!
I started the Process of lightening up the doors.
I should get about 20# of glass, Window regulators, rustproofing and excess steel out of each door.
Some pics below:
New Trans Kickdown Adjustment - Eliminating the Kickdown linkage / Cable from Carb. - Since the Car actually just runs mostly at WOT there is no need for a cable.
Rear Doors Lexan Template
Rear Goor Gutted
Next 3 Shots are of the Metal, components and Sound deadner removed from the door.
Everything removed from rear door is 20#
Front Door Gets the same treatment Except the Glass track will remain for an operational front window - It will get pulled up and down with an old dog leash or seat belt.
