It is currently Fri May 08, 2026 8:08 pm
 Post subject: Distributor O ring?
PostPosted: Sat Nov 27, 2010 5:00 am
Does anybody know the specs on the O ring that goes on the distributor shaft housing? I was going to go to the auto store and just look through their assortment. But, they are dimensioned, and if I knew what size was called for, I could look at those specs on the plastic envelope they come in.
Thanks.
Sam
PostPosted: Sat Nov 27, 2010 5:43 pm
I just used one from the large assortment from Harbor Freight......
PostPosted: Sat Nov 27, 2010 7:44 pm
I guess I should buy that assortment. There is a retail Harbor Freight locally here. I will check them out.
Sam
PostPosted: Sat Nov 27, 2010 7:48 pm
Look in newspapers and magazines for the 20% off coupon and a freebie.....
Print off the online price, if it's cheaper than the store price they'll give you the online price (at least they do in CA)
PostPosted: Sat Nov 27, 2010 8:52 pm
I have been behind customs at the counter at Harbor Freight who have done that. It seems to help if the customer is a pretty girl. I am neither. But, I will give it a try.
Sam
PostPosted: Sun Nov 28, 2010 6:27 am
Hey Sam
Maybe the cashier will be the Pretty Girl. We certainly have some at our stores here.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Nov 28, 2010 2:56 pm
I guess that is a bonus even if you don't get the discount. They say those Suthern girls are mighty pretty. (Don't let the Northern ladies know I said that.)
Sam
PostPosted: Sun Nov 28, 2010 5:15 pm
Contributor
Info....the last FelPro overhaul gasket set I bought contained an O-ring for the distributor, but it was way too fat. I don't know who came up with that size, but I had to search through my collection to find one that fit, and it was much thinner.
PostPosted: Mon Nov 29, 2010 8:21 pm
Car Model: 1968 A108 225/3 on the tree
i have 3 distributor bodies on my bench and they all take different sized O rings.
i also found one to set in the tapered space where at the top od the dizzy hole.
D~~~!
PostPosted: Tue Nov 30, 2010 9:44 pm
My Felpro gasket set had a bunch of O rings, non of them would fit. So I didn't bother using one. No leaks.
Users browsing this forum: Google [Bot] and 7 guests
