It is currently Mon Jun 15, 2026 11:42 am
PostPosted: Wed Dec 29, 2010 8:59 pm
If you keep stomping on the gas, can you keep it running? I had a Holley 1920 like that. The idle circuit was fubar, had to replace it.
Also, did you try a known good ballast resistor?
PostPosted: Thu Dec 30, 2010 12:46 am
Make sure the throttle cable has enough slack to allow the primary to close completely. I've made that mistake before and spent a few minutes scratching my head as to why an engine wouldn't idle below 900 RPM before I remembered to put some slack back in the throttle cable.
PostPosted: Thu Dec 30, 2010 12:51 am
Also, some people have reported that the Mr. Gasket adapter to run the big two barrel carbs on the Super Six intake are prone to vacuum leaks unless sealed with RTV sealant or JB Weld. Double check you aren't sucking air around the adapter plate.
PostPosted: Thu Dec 30, 2010 4:40 am
cable is long enough and slack enough
plus I have a spring pulling it back
and it shuts completely
I also sprayed carb cleaner around the carb and heard no changes in engine speed
I will try it again as soon as I get it to run again
and again - this has electronic ignition and no ballast resistor used
dan
"I may be slow, but at least I'm not very fast!"
'69 A108 - 225, 727, 3.55, MSD6AL, a.k.a.-the brick
PostPosted: Thu Dec 30, 2010 11:55 am
I got it to run!
So I let it stay running and warm up
Farted around with the idle screws etc
Had it where it sounded okay
right about the time the thermostat opened (is my guess)
it sprayed all the water out of the radiator!!!
so I let it sit for a little while and added water
took about 1/2 a gallon
checked the oil
perfect
fired it up again and watched
water lines to the heater are both hot
waited - right about when the thermostat opens
this time without the radiator cap on
it burped and pushed all the water out
was like NiagraFalls - lol
hahahahahahaha
wa
did
i
say
about bad luck???
hahahaha
okay - what is happening with this thing now guys??
hahaha
dan
PostPosted: Thu Dec 30, 2010 12:00 pm
Sounds like the thermostat is NOT opening. Probably have an air bubble at the thermostat.
PostPosted: Thu Dec 30, 2010 12:29 pm
Jack up the front end or point the nose up a moderate hill to help any air bubbles work their way past the thermostat. Then run it with the rad cap off and when it get to the point where the coolant is flowing good fill the rad until the coolant is about three inches below the neck of the radiator.
PostPosted: Thu Dec 30, 2010 1:52 pm
3"s below???????
That puts the liquid in the middle of the radiator Reed!! LOLOL
I ripped the damn thing out and fired it up - it was a 190 I think
forgot already and I just looked at it 20 minutes ago!
Gonna get a 185 in the next day or two
Anyway, it's running - need to adjust the spring that pulls everything shut but it seems to be getting closer
later
dan
PostPosted: Thu Dec 30, 2010 2:19 pm
6 Pack Dart
Dan on the thermostat, drill a small hole about 1/16" in the flange portion. This will alow the air not to be trapped behind the thermostat and doesn't hurt the function of it either.
Richard
PostPosted: Thu Dec 30, 2010 2:39 pm
3"s below???????
dan
I would run a 195 in it. Keeps engine temp up=more power and more MPG. Lowers emissions. Makes it harder to over heat. HOW? Slows down the water going through the radiator which gives it more time to loose heat. Running with out a thermostat will over heat-water runs through radiator to fast and can't give up its heat. If you have a after market over flow tank you can fill it to the top. If you are running a totally stock radiator then you need to fill to no higher than 2" below the filler, you need to leave room for thermal expansion.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Thu Dec 30, 2010 3:10 pm
Richard
the one I took out has a hole in it already!!
learned that one from ya'll
years ago!
I think it's just toast is all
at least it's back running again even if it is acting like the timing is still off
and I am thinking way off
i put the light to it and it is shaking around 2"s away from the mark!
lol
guess i'll just keep messing with it till it get's where it runs okay again and save some money so i can make a trip up north to see my bud and visit a few of ya'll along the way
maybe by the time i get back from Tacoma it will be running in the 15's??
hahahahaha
yea right! be lucky to make it to town right now!!
PostPosted: Fri Dec 31, 2010 5:07 pm
okee dokee
new thermostat in
and it runs fine
(drilled new hole in it too Richard!)
now I haven't taken it out on the open road yet - but it's alive
still not happy with the way it runs
but i am sure it has to do with the timing/distributor
which is causing the carb to not have enough uummpphh to keep it going?
if it had a choke on it - it would probably work better
or more than likely - a smaller carb would work better
anyway
hard to tell where it heads next
since this is newyearseve and tomorrow is the new year
it means i am probably not going very far for a day or two
happy new year ya'll
later
dam
oooppppsss
i meant
dan
PostPosted: Sat Jan 01, 2011 11:30 am
Okay - in the snow, it started and I ran it down to the store - 3.5 miles.
It runs okay once it's warmed up but I noticed that when I stomp it - it acts like it's loading up. Also, I need to back the dist off a bit as it's pinging when I run up the hills.
Still not running right - but at least it's running again.
Later
d
PostPosted: Sun Feb 27, 2011 9:24 pm
Car Model: 1965 Barracuda 'S' auto
Wow, you got some gremlins in there for sure. That carb looks like an 1850 cut the other way than a 2300, you know common throttle shaft and such. Anyway, I used to do a lot of dicking with Holley 4bbls mostly 3310's and the big 850 DP's and found some info from a Demon distributor in Beaver Creek, OR. Anyway, he told me and I found it in writing later, that if you cant get an idle with the transfer slot on the primary side covered up until the width is the same as the hight showing (shaped like a perfect square) Just a C hair showing, you need to open the secondary butterfly with either the adjustment found UNDER the boss that has the secondary linkage stop (needs almost a jewelers screwdriver to reach up in the well) a touch to let some air through the secondary, or start drilling holes in the secondary throttle blade. Holley built in this adjustment on some of their HP carbs, right down through the air cleaner hole with an allen wrench. This should get you back on the idle circuit. Then its jetting from there. There was a way to put your hand over the intake and if the RPM's fell or rose that told you what direction to jet, and also if you cant get the idle screws to make any adjustments in the richness or idle quality, you were still jetted wrong. Look up "Demon tuning" on a Google search, that might get that carb in the ballpark. Then again, a carb too large is murder to tune.
PostPosted: Mon Feb 28, 2011 2:51 pm
Wow - forgot to respond to ya'll and let ya know what's happnen!
got it running - and once it warms up -(NO choke ya know) it runs pretty well - EXCEPT that when I come to a stop, if I do not pay attention to it, it will die
in park or neutral - the idle is about 900 when warm
and in gear around 750
i am positive that I have a vacuum leak - not around the carb, but on the damn intake/exhaust gaskets again
i really need to get the good set and get rid of the cheapies on it
i took a guy out on a quick run - he has seen this thing for years and was curious as to what it ran like - took him out to the freeway and scared the crap out of him !!! LOLOL
we got back and he told the people he ran into about the run and how it was no where near like the van his "brother" once had
this thing runs like a sob when it is out and about - it's just that it has a hard time off the line if i do not pay attention - it has the bog crap going at this point
it definitely has a TON of mid-range - like when i hit the onramp for the freeway and drop it into 2nd gear (at 40+mph)and stomp it - i can pass anything on the freeway that i want - even out on the road doing whatever the traffic is doing - (and we all know that freeway traffic is not doing 70!!)
all i have to do is punch it and away we go - and it sounds good too
remember ya'll - this is a brick - and it flies when i want it to
seems to be getting really good fuel mileage at this point again too
doesn't matter how much weight i have in it either
Reed sent me a 2280 carb and it scares me to think about changing it right now - partly because i do not have all the gaskets it will need to install it - but also because it is HALF the size of the 500 on it right now!
told Reed that it looks like it should be on one of my lawn mowers compared to the 500 on it right now!! hahahahaha
anyway - between
no choke
unsure of adjustments of carb and timing
no kick down linkage
"plain jane torque converter" -(need something a little bigger than stock)
bad back
no money
and blahblahblah
it's running fine for now!! LOL
hay - it's running and reliable again for now
so i am not complaining!!! (ya right!!!LOLOL)
hahahahah
later
dan
