It is currently Fri Nov 13, 2026 9:26 pm
PostPosted: Fri Oct 29, 2010 3:06 am
Hi all, the old thread is getting really crowded so I hope its ok to make a new thread on this SLOW restoration...
Someone has really screwed up my '66 Dart somewhere along the line...
SOLEX - British Made! :P
Oh while im at it... saw a crack on the exhaust manifold (hope can be welded)
took the transmission apart and gave it a good clean...
Cleaned the head and grind the valves... and seats...
Number '65 was stamped on both LH and RH side of the transmission... so i assume this is a '65 trans on a '66 body...
Will update more later :)
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Fri Oct 29, 2010 3:10 am
Forgot how to decipher it, but the clocklike stamp with the 65 in the middle is when that part was cast.
Sometime in 65 for a 66 model year makes sense....
(I'd say sometime in August)
PostPosted: Fri Oct 29, 2010 4:57 am
yes a 65 tranny would have the ball/trunion connection-- not the slip joint, Lawrence
PostPosted: Fri Oct 29, 2010 7:43 am
I think its a '66 too, coz the tail shaft extension seal is "booted" like this:
Only '66 - '72 has this type of extension seal rite?
PostPosted: Fri Oct 29, 2010 2:55 pm
Exhaust manifolds almost never stay together after welding. If your able I would try and find one that is NOS.
JMHO
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Oct 29, 2010 7:41 pm
JMHO
Frank
Well it is cast iron and i live in Malaysia... i have the only Slant Six in the whole country :(
To ship the cast iron manifold over would be fun ($$)... speaking of that, anyone has a decent exhaust manifold with no cracks?
Thanks.
Syed
PostPosted: Sun Nov 14, 2010 1:43 am
More parts arrived in the mail today... The Customs officers are Loving me for this... :)
More to come...
PostPosted: Sat Jan 08, 2011 5:05 am
Finally got the Dart on ramp and took out the rear end and leaf springs. Monday should be able to get the front lower and upper arms out. Then will get all sandblasted before putting all new bushings and ball joints etc.
Here are some pix...
on ramp...
Reassembling the motor
C3 CrossFire in the background...
Got the rear end and leaf springs out
Should get some more pixxies on Monday
Cheers
PostPosted: Tue Jan 11, 2011 2:09 am
Almost done assembling the engine...
Brakes and suspension parts are disassembled and sent for sandblasting
More pictures to come once the parts are sand blasted :P
