It is currently Sat Jul 18, 2026 12:28 am
Post new topic  Reply to topic  [ 1356 posts ]  Go to page Previous 115 16 17 18 1991 Next
PostPosted: Mon Jan 17, 2011 11:30 pm
I predict anouther 40lbs by April.Mark
 Post subject: More Weight Loss 1-19-11
PostPosted: Wed Jan 19, 2011 9:08 pm
Well Mark I beat your prediction by oh 2.5 Months!
I got the windshield out -25#
Dash removed -25#
Other Misc. Items Removed - Sheet metal Braces wiper mounting Reinforcements, Steering column Braces Windshield Gasket / Stainless Trim:
-9#
So for today I got another 59# out of the front of the car.
Running total so far: 256# lighter than 2010.. That will go down a bit when I account for the lexan front and rear glass. it's not here yet.
Also I am Going to remove the Rear window... I guess 25#'s there and some more undercoating 2-3#'s there, and the rear bumper and support brakets - Maybe 30+ #'s there?
I did some relocation of the Gauges, switches and wiring, Still have to add the tach Back in. I built a real simple AL strap to support the steering column to the Interior Frame.. The One Chrysler gives you is like 3#'s It's built for a mack truck!
Pics:
Windshield Removed
Dash Removed; Mark should bee happy!
Gauge / Switch Panel Reinstall Pics:
PostPosted: Wed Jan 19, 2011 9:33 pm
I meant 40 more off from TODAY.Steering wheel,turn signal switch and a stock non cut colum look out of place and heavy.I am proud of you.What did the car weigh before you started this diet?Mark
PostPosted: Thu Jan 20, 2011 10:23 am
Mark,
This is the 2010 Weight..
2575# W/O driver
2775 with Driver.
PostPosted: Thu Jan 20, 2011 10:28 am
You should be in the 12s now... Nice work.
PostPosted: Thu Jan 20, 2011 9:04 pm
According to the Wallace calculater,if you get the car with driver,,,which you will,,,down to 2500lbs,going by your best times and mph, you should go 12.81@ 104.57.YAHOO!!!!Weight removal is like FREE hp.Keep hacking.Mark
PostPosted: Fri Jan 21, 2011 5:44 am
do me one favour, don`t remove that grill to save weight, it the coolest front on a valaint. 8)
PostPosted: Fri Jan 21, 2011 8:49 am
Thanks for the predictions Mark, I am not sure however that you calculations account for the future gear change form 4.30 to 4.56 and the aero Stuff / Stance.
Terry, I might Experiment with covering it, but i'ts pretty light as it is now. The grille as it is now ismade of all thin sheet Aluminum and a whole bunch of holes already punched in it.
I got the back Window removed, ready for some lexan to go in there.
Rear Glass -17#
Rear Glass Gasket, Trim, Clips etc. - 5#
Running total weight loss: Since November 2010 278#
PostPosted: Fri Jan 21, 2011 9:51 am
You are getting to Possum Parker weight range, and engine performance appears similar, esp with a little more tuning. It'll be interesting to see you run Gary Bruner or Parker this year...
PostPosted: Fri Jan 21, 2011 11:59 am
Maybe I'll Just have to go Possum huntin and get me a Bagel bamboolzer too!
 Post subject: Bamboozaler
PostPosted: Fri Jan 21, 2011 1:54 pm
I have heard much talk about the Bagel bamboozaler, but I have yet to see one in captivity. If you locate one or see one in the wild will you please take a picture of it for us! :lol: :lol:
Rick
PostPosted: Fri Jan 21, 2011 5:18 pm
Well I got the Lexan rear window in - The Sheet Blank Arrived today and I wased no time getting it installed. Mason Dixon opening day / TNT is less than 2 months away!
Here are Some Pics:
I began By transferring the outer shape of the rear window to Cardboard.
Lots of compound Curves here that are tough to match on flat sheet.
Bye Bye Rear Glass / Gasket.
Sheet Blank - Gave me a few inches extra on all sides.
Template Transferred to lexan sheet - Lots of cutting, roughing in and test fits to get this correct.. I cant imagine doing this on a 64-66 Barracuda.
Install Complete. Lexan only adds 6# back to the car! YAY!
Lexan Rear Glass +6#
Total Weight Loss since November 2010 Now @ 272#
PostPosted: Sat Jan 22, 2011 7:45 am
Good work. That is a tedious job.
 Post subject: Guzzi Stylin' 1-23-11
PostPosted: Sun Jan 23, 2011 4:31 pm
Well Another update - We had a snow day on Friday so I had a 3 Day workin on Ruster weekend.
I made a Support bar for the parking brake - It used to conncet to the dash which is gone..
I made A "pocket" for my Junk that used to reside in the Glove box. Used an old Pant leg and basically riveted it to the floor.
I got the 5 point racing belts installed!
Fabbed up some grille Coverings:
Terry, The grille is not gone, just Covered - They are easily removed with 2 Bolts.
I am also Thinking of going with the '67 Center Grille piece if I can find one :-)
PostPosted: Sun Jan 23, 2011 4:39 pm
How'd I get drug into this? :shock:
I have no idea what a Bagel Bamboozler is either. :?
