It is currently Sun Jun 14, 2026 12:27 am
PostPosted: Fri Jan 21, 2011 12:29 pm
My 1986 Dodge D150 truck makes a clicking noise when coasting, even with the engine off. I have jacked up the car and spun the front wheels and could hear no clicking noise. It makes the noise at low speed. I have an automatic transmission. Could it be the speedometer cable? Any ideas on how to troubleshoot this problem?
PostPosted: Fri Jan 21, 2011 12:35 pm
Can be hub caps to. Some times they "walk" around the rim, can even pull out a valve stem!
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Fri Jan 21, 2011 12:58 pm
Sounds like there is no adhesive on the shim that attaches to the pads. Check to see if there is some, if not, put some on.
PostPosted: Fri Jan 21, 2011 1:41 pm
If it was the speedometer cable it would cause the needle to jump in time to the click.
PostPosted: Fri Jan 21, 2011 1:48 pm
Both my 83 Dodge van and my brother's 83 Dodge van have a click like you describe from the front right disc brake caliper. Try coasting and applying the brakes- I bet the click goes away.
When you put new pads on the calipers, you are supposed to bend the locating tabs so the pad grips tightly to the caliper. I did this on my brother's van and the clunking went away for a few months, but came back. I think the stress of stopping the van slowly stretches the tabs out enough to where the clunking comes back.
PostPosted: Fri Jan 21, 2011 1:49 pm
Speedometer does not jump. I will check the shim on the brake pads. Thanks.
PostPosted: Sat Jan 22, 2011 5:12 pm
check front wheel bearings ....repack....adjust
PostPosted: Sun Jan 23, 2011 6:45 am
Dry “Uâ€￾ joint cap will sometimes make a clicking sound.
PostPosted: Sun Jan 23, 2011 9:32 am
Yep I have Had a car on 2 that does that...
Pull 4 caps if you got em then drive again.. If no noise you found the problem.
PostPosted: Mon Jan 24, 2011 8:54 am
Contributor
I've also had a small rock get inside a hub cap and make a click.
PostPosted: Mon Jan 24, 2011 11:17 am
Are you sure its coming from the front?
One time I had a clicking sound and it turned out to be the rear brake. That metal bar/bracket that goes from one shoe to another was tapping the back side of one of the wheel studs and causing a clicking sound when rolling.
PostPosted: Mon Jan 24, 2011 5:11 pm
Could be a stone caught in the tire treads. Does it click at the same speed as the tires/wheels? Louder if you are next to a wall?
