It is currently Sat Dec 27, 2025 1:04 pm
PostPosted: Mon Jan 24, 2011 7:30 pm
searching in a local junk yard and found a '77 aspen with a slant 6 2 barrel. decals under hood show 225 2bbl. nothing says super six so my question is are all 2 bbl /6's super six's?
thanks
PostPosted: Mon Jan 24, 2011 7:38 pm
Yes, all passenger cars and light trucks with 2bbl carbs are considered to be Super Sixes. They were introduced for the 1978 model year.
PostPosted: Mon Jan 24, 2011 7:55 pm
will that intake/exhaust bolt on to a '71 cylinder head?
PostPosted: Mon Jan 24, 2011 7:59 pm
Not to toot my own horn, but you need to read THIS
PostPosted: Mon Jan 24, 2011 8:12 pm
Thank you, looks like plenty of info.
PostPosted: Mon Jan 24, 2011 9:19 pm
Toot that horn... it's probably the most viewed article on the site :)
PostPosted: Mon Jan 24, 2011 10:28 pm
That's too bad. There are some VERY informative and much more edifying articles than that one. Actually, I don't know why my name is still on it. Doc has done extensive editing and upgrading to it. I may have helped do the initial draft, but he has taken it to a much higher level than I ever did.
Anyway, it still answers most all of the questions about a Super Six upgrade. The only things I would change would be to add some discussion of adding a Super Six to a van and to add a recommendation that people try and use cable style kickdown linkages since the factory correct ones are getting scarce. A discussion of how to make your own two barrel intake would also be helpful.
PostPosted: Tue Jan 25, 2011 2:11 am
Yep, discussing a Lokar and Bouchillon kickdown would be great, maybe even a link on how to set them up properly. Also some automatic choke options. It's nice to have everything you need on one page. Oh yeah, can't forget the part #'s of manifold hardware :)
PostPosted: Tue Jan 25, 2011 6:06 am
Toot that horn Reed! 8)
'78 Volare 225
'67 Charger 318
PostPosted: Tue Jan 25, 2011 6:54 am
Extreamly nice article. Future update should possiably include
mention of aussie gaskets, they tell me they are sweet.
but by all means,
toot that horn sir.
rooster
if it has breasts,wheels,or freon it requires constant attention.
PostPosted: Tue Jan 25, 2011 11:59 am
Toot! Toot! The Reed Express is passing through!
Excellent article, but I second the recommendation on the Aussie gaskets. They are real problem solvers!
Users browsing this forum: Bing [Bot] and 25 guests
