It is currently Sat Jun 13, 2026 6:08 pm
 Post subject: the sway bars...
PostPosted: Tue Feb 01, 2011 12:02 pm
okay you probably have answered this... and if you have i apologize just post a link and i will thank you from the bottom of my heart
im looking for sway bars... front and back... i found a few kits... from jegs and from carjunky
Jegs:
http://www.jegs.com/i/ADDCO/020/675/100 ... tId=751596
carjunky:
http://www.carjunky.com/partstore/?N=11 ... 4294952330 *3rd one down*
now those are 2 different ones... the jegs is rear and the hellwig is front
my question is... are these any good?? or do you know of bettter for around the same price? *also these are kits*
74 plymouth duster, 225 single barrel slant six
PostPosted: Tue Feb 01, 2011 1:51 pm
lookhere.
I have an Addco 1 1/4" front bar, not happy with its bushing mounting method, very happy with its price. It worked so-so.... I'm in the process of a bushing mount redesign.
PostPosted: Tue Feb 01, 2011 3:38 pm
the prices are nearly double for each of them, its around 700 dollars for those sway bars compared to 300 for the other ones...
PostPosted: Tue Feb 01, 2011 4:02 pm
I think a 7/8 rear bar is too big for use with a slant six...
The addco rear mounting isn't all that bad.
It's the front mount you have to fix and improve.
PostPosted: Tue Feb 01, 2011 4:10 pm
what about hellwig as a company? i have never heard of them before this day...
PostPosted: Tue Feb 01, 2011 10:16 pm
One thing to consider is what year car is it going on? That affects how it mounts, no? I have an Addco front bar on my '76, that I got here:
http://justsuspension.com/front-sway-bar-kit-5905.html
The mounting hardware it came with looked okay, but I had a set of LCA's with factory sway bar tabs, so I used those.
I have an unknown origin rear bar hanging on the shop wall, but I'm waiting until I have the car all sorted out and dialed in, to see if I even want to run it.
PostPosted: Tue Feb 01, 2011 11:00 pm
So I just noticed on the link I provided above... Looks like Just Suspension has switched suppliers since I bought mine.
PostPosted: Wed Feb 02, 2011 11:23 am
its going on a 74 Plymouth duster.
PostPosted: Wed Feb 02, 2011 12:40 pm
On a '74 the Addco 186 front sway bar is fine because the chassis mounting is completely different. It's in stock at Summit. http://www.summitracing.com/parts/ACO-186/
I agree the 7/8" rear sway bar is too much. 5/8" is probably about right, but 3/4" appears to be the smallest. http://www.summitracing.com/parts/ACO-919/
PostPosted: Wed Feb 02, 2011 1:11 pm
oh thank you skinner... *bow* you have saved me money... you are a good person.
PostPosted: Wed Feb 02, 2011 1:59 pm
Thanks, I hate seeing people pay too much or get the wrong parts. Also, with a 3/4" rear sway bar the car is probably going to be tail happy at the limit. I would suggest you test the car in a safe place and find the handling limits where it won't cost you a wreck or worse.
Right now my Valiant has 1.04" torsion bars and no sway bars. It corners quite well, but I may add a front sway bar and drop the torsion bar size a bit to soften the ride slightly. The big thing with running high rate torsion bars is the shocks. I have QA1 single adjustable shocks on the Valiant. I have Bilstein shocks on the front of my '66 Barracuda (it's a race car project) with 1.14" torsion bars, but haven't road tested it yet. I expect it will be fine as a friend has 1.20" torsion bars on his '68 Valiant with the same shocks and it rides quite well.
PostPosted: Wed Feb 02, 2011 7:02 pm
Car Model: Road Runner
Hotchkis provides awesome front and rear sway bars. You can buy them each or as a kit.
PostPosted: Wed Feb 09, 2011 10:29 am
again... 683 dollars for their kit... better than some... but when i can pick up what i need for 300 or less... >.> thats always good
PostPosted: Thu Feb 10, 2011 9:48 pm
www.firmfeel.com is the place to go for Mopar suspension stuff. Hellwig has good bars also.
PostPosted: Fri Feb 11, 2011 10:47 am
I've used Hellwig stuff for years and always been happy. Have one on the front of my 1970 Challenger...
Scott - waywardgarage.com
Why is the rum always gone? Image
Users browsing this forum: eric22t and 3 guests
