It is currently Mon Dec 02, 2024 12:10 am
PostPosted: Sat Feb 05, 2011 11:35 am
Does anyone have an old TRW engine parts catalog available?, I need to know the application for TRW part number 44812 push rod. Thanks.
PostPosted: Sat Feb 05, 2011 2:07 pm
I have a 93 book.
But are you sure about that part number, the pushrods I'm finding are all 48xxx
Rocker arms are 44xxx, but no match.
PostPosted: Sun Feb 06, 2011 7:33 am
OOpps :oops: number is 48812
PostPosted: Sun Feb 06, 2011 11:30 am
48xxx are normal pushrods
488xx are premium pushrods
and
it's older than 1973 which is as far as my book goes back too.....
But I found this:
Part Name: PUSHROD
Part Number: 48012 $4.50
Kit # Name
CV216M40 CHEVROLET, 216 CI, 1940
CV216M41-47 CHEVROLET, 216 CI, 1941-1947
CV216M48-49 CHEVROLET, 216 CI, 1948-1949
CV216M50-52 CHEVROLET, 216 CI, 1950-1952
here:
http://www.egge.com/site/?d=48&dt=1&SubCategoryId=21
Then I looked up 52 chevy truck at rockauto.
Get part number rp3019; 10.465 length , ball and cup for ends
PostPosted: Sun Feb 06, 2011 12:19 pm
These are pushrods I used to get back in the late 70's early 80's to make custom length 170 slant pushrods. They were real easy to shorten and much cheaper then custom pushrods or the MP pushrod kit. I am trying to find 4 more of an equivelent part, to have a full set.
They are 3/8 dia tubular, 9.325 overall length, ball and socket, no oil hole, and the cup end is just a press fit. They can be cut with a tubing cutter, counter drilled, and the cup reinstalled. At the time I was buying them, I think they were less then $2.00 ea. I don't remember what the original app was. I picked them out of the progressive size chart, in the back of the catalog.
PostPosted: Sun Feb 06, 2011 7:14 pm
Well crap, I looked up the wrong part number....
Same place, but try this:
Part Name: "60-67 FO/MER 352,390,406,427"
Part Number: 48812
Cross referenced to 67 7.0 (427) LTD
Sealed power rp3230R ball and cup 9.33"
PostPosted: Sat Feb 12, 2011 1:55 am
From 1973 Trw Perf catalog,
TP 112 cam 453/453 valve lift, 302/302 cam lift, 284/284 dur, 55° overlap Hyd.
Rest must be newer as they are not in book besides .010 main and rod bearings.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 6 guests
