It is currently Sat Jun 13, 2026 5:27 pm
 Post subject: CAR WON"T START
PostPosted: Tue Feb 15, 2011 3:51 pm
TIMING - OKAY, FUEL - OKAY, COMPRESSION - OKAY, SPARK PLUGS GETTING ELECTRIC - OKAY.
Okay, we have the timing at TDC right after the compression. The spark plugs go off okay. Fuel is going in okay. Compression on cyl 1 is 150. So if we have the timing electric, fuel, and compression okay, what possibly could we be missing?
It has a Pertronix II Ignitor, but like I said, the plugs get spark.
Any ideas? Thanks.
PostPosted: Tue Feb 15, 2011 5:20 pm
Sometimes you just have to pat the valve cover while whispering kind words... :lol:
Are you sure the spark is powerful enough? Have you done some work to the engine or car recently that may have upset something?
Olaf
Aspenized
PostPosted: Tue Feb 15, 2011 5:32 pm
I put an offy intake and Clifford headers on the car. After starting it, it sounded like the timing was off. So I messed with the distributor by putting the rotor one over, and tried that, and he wouldn't start. So did it the other way, and the same. So I put it back where it was, and didn't start. I had a friend come over today, and he made sure it was at TDC. He said the spark looks great. The coil is a hot one.
PostPosted: Tue Feb 15, 2011 9:44 pm
Are you SURE the TDC you have is on the compression stroke of # 1 cylinder? There are 2 revolutions for every TDC compression on # 1. Is it possible you are using the exhaust TDC ?
If everything else is as you say,then he should go.
The only other thing I can think of,is a really big vacuum leak in your new intake somewhere,and too lean to start. You could try splashing a spoonful or 2 of gas down the carb and see if it will fire then.
regards,Rod. :?
PostPosted: Wed Feb 16, 2011 4:22 am
Before I had my buddy helping me, I opened the valve cover, and brought the timing mark to 0. I took out the spark plug, and felt the piston. At this point, both valves were shut. As I slowly advanced the crankshaft, the exhaust valve started opening.
My buddy on the other hand, put a compression tester on Cylinder 1, and turned the crank until he saw the compression on the tester, and then slowly turned it to 0.
I will try that fuel down the carb. Thanks.
PostPosted: Wed Feb 16, 2011 5:20 am
Well, it looks like the timing is correct. I poured some fuel in the carb, and it fired right up. But once it burned that fuel, dead. So I waited a minute, and then pumped the carb to get more fuel in there, and then tried to start it. It started again, with a huge blast of fire coming out of the carb, and it ran until it burned that fuel. Making progress now.
But now I have to check out the carb and intake manifold I guess.
PostPosted: Wed Feb 16, 2011 8:52 am
READY FOR PIPE WORK NOW. Finally got the timing where it will run ok. I am taking it in tomorrow for the pipe work, since the pipe guy is leaving early today.
