It is currently Mon Feb 24, 2025 6:12 am
Post new topic  Reply to topic  [ 97 posts ]  Go to page Previous 13 4 5 6 7 Next
PostPosted: Wed Oct 27, 2010 3:52 pm
Josh, when you get yours I would be interested in how the clutch cross shaft attaches. I am using an Aspen bellhousing now with my A833OD and it works fine but I have always been reluctant to drop the clutch at 5000 which is necessary to get the good 60' times. If I had an SFI bellhousing I would be more brave, I have an old 9 1/4" Weber clutch with an nodular pressure ring that I could dig out. It's is pretty unbelievable that someone would go to the trouble of making a piece like this at this time.
PostPosted: Wed Oct 27, 2010 4:26 pm
I'll make sure to take a picture of the cross shaft area when the bellhousing arrives.
I also have a 9 1/4" Weber clutch cover, but I can't tell if it has a nodular pressure plate or not. I hope so. I'm going to use it in my Valiant street car. The Bonneville Barracuda will use a Spec clutch.
With the economy the way it is it seems people/companies are willing to do more work to keep afloat. Something that would have likely never happened in 2007 is suddenly possible. Being a little bit hungry may be a good thing.
PostPosted: Thu Oct 28, 2010 5:04 pm
yea but unfortunately small business isn't the only hungry ones..........
-Mike
I am the Guardian, I hate helos, everything leaks.......
 Post subject: Finally!
PostPosted: Mon Feb 14, 2011 3:05 pm
A little under $600 shipped because I asked nice and was patient.
PostPosted: Mon Feb 14, 2011 4:01 pm
Hey, that's cool!!
Scott - waywardgarage.com
Why is the rum always gone? Image
PostPosted: Tue Feb 15, 2011 5:39 am
Nice. What trannys does that one fit? Can anyone order these now?
PostPosted: Tue Feb 15, 2011 10:45 am
This one fits the Chrysler 3 and 4-speeds. RM-7072 is the part number.
From e-mail...
Joshua,
We now have this part number set up in our system and have inventory available.
Regards,
Jim Puskas
Hays/Lakewood Specialty Products
QuickTime Bellhousings
216-688-8300 ext. 264
PostPosted: Tue Feb 15, 2011 11:08 am
Interesting. I don't see how the (supposedly) exchangable adapter plate attaches to the bell.
I am interested in mounting a T56, T5, or GM (gulp) 46LE or whatever their 4spd auto is called.
PostPosted: Tue Feb 15, 2011 11:15 am
They weld a different transmission-side plate to the body of the bell.
PostPosted: Tue Feb 15, 2011 11:45 am
Ahh, thanks! That is a nice and strong (if less flexible) way to do it.
Assumedly any trans pattern can be ordered then...
 Post subject: hole size
PostPosted: Tue Feb 15, 2011 6:37 pm
Did you ever find out why the hole size in the bell is so big and not like any of Mopars transmissions?
Rick
 Post subject: Re: hole size
PostPosted: Tue Feb 15, 2011 7:22 pm
Because someone sent Ross at Quicktime a bellhousing with a big hole in it.
Rick
PostPosted: Wed Feb 16, 2011 5:08 am
Isn't it just the OD 833 bearing retainer size??
Oh, I see, it looks like they sent you an adapter ring for your trans.
PostPosted: Fri Feb 18, 2011 9:14 pm
so this can be ordered with the T5/T45/T56 bolt pattern ??
-Mike
PostPosted: Fri Feb 18, 2011 10:10 pm
Car Model: Toad Wagon
Gentlemen, I ordered one (of two left from the first run) yesterday. No comment was made regarding the time of another run.
Sex, drags, and rock & roll.
Dick, 225% crazy.
Users browsing this forum: No registered users and 27 guests
