It is currently Mon Jun 22, 2026 8:02 am
 Post subject: 1969 225
PostPosted: Sat Feb 19, 2011 12:12 pm
any idea if a 69 225 will fit in a 78 volare or do i have to change the pan?
 Post subject: Yes if...
PostPosted: Sat Feb 19, 2011 2:36 pm
If it is truly a 1969 block/crank and from a 1969 Dart/Valiant it should go right in without much fanfare.
PostPosted: Sat Feb 19, 2011 3:14 pm
its out of a 1969 satellite
 Post subject: Check...
PostPosted: Sat Feb 19, 2011 6:38 pm
You should be able to make this swap...assuming it's the original engine or if replaced, the previous owner used a 1968+ engine...if someone decided to put a 1967 or earlier motor and tranny in it then it won't work...
Have you looked at the ID pad near the #1 spark plug and alternator bracket to see what numbers it has.
