It is currently Thu Nov 12, 2026 4:19 pm
 Post subject: Rebuild question
PostPosted: Mon Feb 21, 2011 7:10 pm
Ryan and I disassembled his 4 speed OD this evening and I have a question. The spacer tube inside the cluster gear is not solid. It is split end to end. I noticed that on each end of the tube there is a noticeable gap. The center about 4 inches of the tube is tight together. But on each end it is opened up some. Is this normal? Something to worry about. This is just a spacer if I'm not mistaken and can't see how it would have been spread apart in normal operation. Want to start reassembly tomorrow.
Thanks,
Rick
PostPosted: Mon Feb 21, 2011 7:36 pm
#50?
 Post subject: Correct
PostPosted: Tue Feb 22, 2011 3:55 am
Yes #50
 Post subject: Bump
PostPosted: Tue Feb 22, 2011 11:49 am
Plan to start going back together in about 2 hours. Any opinions?
Rick
PostPosted: Tue Feb 22, 2011 2:16 pm
Online
Rick, I cant rembember how mine looked when I had them apart.
Sorry.
But if it's a real concern, Just weld the opened ends toghter and grind / file them down smooth.
 Post subject: Thanks
PostPosted: Tue Feb 22, 2011 2:59 pm
Thanks Greg, I wasn't really worried. I just didn't know if I was supposed to be. :D
Rick
 Post subject: Wha happen?
PostPosted: Thu Feb 24, 2011 7:36 pm
So did you assemble as is?
 Post subject: plans changed
PostPosted: Fri Feb 25, 2011 4:08 am
Well,
Plans changed and I didn't get to it as quickly as I thought, but I am going to install it as is. I cant see any reason not too.
Rick
PostPosted: Fri Feb 25, 2011 4:25 pm
Rick, How about giving Jammie Passion a call,570-401-8949. I am sure he will be able to fill you in on all the 4 speed info you want. Good guy and willing to help. + he is a fellow PAer not toooo far from you.
 Post subject: All is well
PostPosted: Fri Feb 25, 2011 6:01 pm
I already assembled it. I'm sure it will be Ok. It is only a spacer.
But the funny thing (Not really so funny) was that when I packed all the new bearings into my cluster gear, guess what I had left over. 1 bearing!! :? So did I pack all of the bearings in there tight or did I leave one out? Oh man! So I pull them back out and count them all and guess what? They sent me 77 bearings instead of 76! They were all in right the first time. So I put them all back in again, and then I forgot the small spacer/washer that goes between the 2 sets of bearings. So out that end comes again!! Packed it up the third time and we are good to go. :lol: Ain't this fun? :lol:
Rick
PostPosted: Sat Feb 26, 2011 6:56 am
I tend to refer to that as "practice". :|
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Sat Feb 26, 2011 7:29 am
I call it oldtimers,,,,,,,,,, ??/ /what was I typing ?? Were am I ???
This is a funny looking television,the remote only has 2 buttons and some kind of wheel?............................... :lol:
 Post subject: Not alone
PostPosted: Sat Feb 26, 2011 7:46 am
It is good to know that we are not alone!! :D
Rick
PostPosted: Sat Feb 26, 2011 9:50 am
Romeo Furio:
Space Command Tuning baby:
http://en.wikipedia.org/wiki/File:Zenit ... er_600.jpg
Morehere
PostPosted: Sat Feb 26, 2011 1:16 pm
It truly amazes me the things you come up with.......
