It is currently Fri Nov 13, 2026 9:20 am
 Post subject: A833 OD Source Vehicles
PostPosted: Thu Mar 03, 2011 7:30 pm
I have a '71 D100 /6 3speed. interested in putting an overdrive trans in it. I have looked at the T5 swap and am interested in that but thought the A833 OD swap might be a little easier. What source vehicles should i look for at my local junk yard? What issues will i have with this swap?
Thanks
 Post subject: These vehicles...
PostPosted: Fri Mar 04, 2011 5:20 am
1975-1987 Dodge Trucks/Vans (Also similar year Plymouth Trucks/Vans)
You will need the bellhousing, tranny, shift rods and shifter. You should have everything else you need already on your 3 speed vehicle.
You may need the floor hump if your rig is a 3on the tree.
PostPosted: Fri Mar 04, 2011 7:59 am
where are you ???? I have a setup here in northeast Pa
PostPosted: Fri Mar 04, 2011 4:31 pm
ESP47 on here is doing this swap right now or soon.
Scott - waywardgarage.com
Why is the rum always gone? Image
