It is currently Mon Dec 22, 2025 6:39 am
Post new topic  Reply to topic  [ 1294 posts ]  Go to page Previous 118 19 20 21 2287 Next
PostPosted: Thu Feb 24, 2011 2:22 pm
I have a set of lowering blocks - Does anyone know if these are legal to use as per IHRA / NHRA rules?
They are 2" aluminum with a centering nub on them.
Look under most any car with SS springs on it that sits at a reasonable height and you will see lowering blocks. I have never seen any rule against them.
PostPosted: Thu Feb 24, 2011 2:25 pm
Thanks Dennis - That's why I asked. Modded Racers are still newer to Me!
PostPosted: Thu Feb 24, 2011 4:41 pm
SL6 Racer
Be careful with the lowering blocks. I tried a set cast aluminum blocks and they crushed under torque. I then made a set out of solid block aluminum. They weren't very light but did the job.
Ron Hamby
PostPosted: Thu Feb 24, 2011 6:20 pm
Ron Hamby
Thanks Ron!
Good tip.
I will look into the construction of these.
I can always get some made at a local Machine shop - I have a guy there that's helped me out with some other oddball requests of mine.
PostPosted: Thu Feb 24, 2011 6:33 pm
You might think about the added leverage the blocks will give to the rear-end housing to wind up the rear springs. :roll:
Richard
Thanks Richard,
I am assuming this is a Negative / undesirable effect?
What would I do to make it right?
I am still a newbie in the racing suspension / Geometry department.
PostPosted: Thu Feb 24, 2011 7:01 pm
6 Pack Dart
Think of how the rear-end flexes the springs into a S shape. It needs to have the front section of the springs held as stiff as possible.
Richard
PostPosted: Thu Feb 24, 2011 7:45 pm
Richard
Got it.
i do have the front segments clamped - I can experiment with more clamps if needed.
PostPosted: Fri Feb 25, 2011 8:50 am
Good day to all, I've installed Caltracs on my Duster but I'm not quite finished and driving just yet to comment on how they work. In doing my homework I noticed alot of mopar stockers using them. I asked a guy that was running them on G/SA Demon if they actually made a difference and said he gained in 60' and et. His car picks both front wheels up equally.
Might be worth lookin into. My two cents.
Thanks Derek
70 Duster 238'', four speed ,3:91's, 500 Elde, Hookers
68 Dart 4 dr 225, completely original
PostPosted: Mon Mar 07, 2011 7:18 pm
Thanks Derek
Thanks for the insight Derek.
I know caltracs are Great for Big HP cars, Say 450 and Up Horsepower, I really do not know if they will help our light Lower Powered slant cars.
Some really fast slant 6 folks Use really Beat to death worn out Stock 5 leaf a body springs with a Few tricks.
For now that's what I am leaning towards for price reasons.
I am not ready to try caltracs yet. But Maybe in the future I will.
I got my 500CFM eddy carb back on and Reworked the Dist. a bit - Re-drilled a Dorman replacement Dist Gear and Shimmed it up for less "bounce / Play"
Also Welded up the advance Weights in the dist. Set it at 28* steady.
Got the Preload, Clearances and gear pattern set up in My 4:56 Spool Pig.
Also Polished My wheels :-0
Still waiting on my windshield to come in from percy's - i should have just bought Flat Sheet and made my own!
Cant wait to get to the track!
PostPosted: Tue Mar 08, 2011 10:35 am
Hey Greg, do you have a vid of the car launching. Does the rear end get pushed into the track or gets sucked back up? Mine with out the Comp Eng Slide-a-Links would plant the rear and then throw it back into the car. I could see the tire loose its wrinkle and then hit again.
My springs are from a 69 BB Cuda, both have 6 leafs and the left has two clamp in the front and one in the rear. Right has two clamps in the front and the rear. Slide-a-links lowered my 60's by one tenth into the low 1.50's. Might want to look into a helper of some sort. I think you're running 12's right? Later
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Tue Mar 08, 2011 10:42 am
I do have some Vid's THat I can review - THey are not the best but At least I can see what it (was doing). From last year:
www.youtube.com/hyperpack
The rear did not appear to do anything last year - Just go straight.
My car had a real soft launch and pretty slow 60' times.
This year might be different.
But I will look into it.
PostPosted: Tue Mar 08, 2011 9:42 pm
I would copy me,,,consistant 1.55 to 1.50 with worn out springs,orig cracked bushings,nothing trick other than added leaf mounted up sidedown forward of the axel.No clamps.Watch how my car leaves with under 300 hp.Guzzi Mark
PostPosted: Wed Mar 09, 2011 3:22 pm
Mad Max, does you susp make your tires dig like this?
8) 8)
PostPosted: Wed Mar 09, 2011 5:47 pm
What kind of dig was that? :P
11.02 @ 120.56
Chassis dyno
PostPosted: Wed Mar 09, 2011 6:08 pm
I was behind Mark at Vegas last year. His car does leave very well for a leaf spring car.
I tried a set of Cal-Tracs on my Duster when it was still running in the 17's. It did not gain any 60' or ET, but it did get way more consistent in the 60' and was much easier to dial in. They are on my '66 now, but I haven't raced it enough to tell if they did much of anything.
It went 1.56 with J.C. Whitney springs, worn out stock shocks, and $19 Lakewood bolt-on slapper bars. :lol: :lol: :lol:
