It is currently Wed Dec 31, 2025 6:07 am
 Post subject: Fuel pump
PostPosted: Wed Mar 09, 2011 5:29 pm
Thinking of blocking off the pump, and getting a red electric holley fuel pump? Anyone had any problems?
And does it matter what kind of carb I get say going from a 1bbl to 4bbl? I won't have any fuel starvation problems?
And easy install? no wiring into the ignition?
cheers
PostPosted: Wed Mar 09, 2011 5:36 pm
You'll want a relay and oil pressure switch wired into the pump power to cut power to the pump when the engine isn't running.
Personally, I think the Holley red pumps are overrated and over priced. Had 2 of them die on me after less than a year's use and they only have a 90 day warranty.
PostPosted: Wed Mar 09, 2011 5:52 pm
Why do you want to do this?
PostPosted: Wed Mar 09, 2011 5:59 pm
Holley pumps of this type are loud! Unless you have need for more fuel volume than the stock pump can provide I would use the stock pump. If you want an electric pump on a street car I would use something else.
PostPosted: Wed Mar 09, 2011 6:32 pm
Just crossed my mind sparked an interest in what would need to be done and how to do it. Thanks guys. And no I won't be doing it unless my fuel pump breaks.
PostPosted: Wed Mar 09, 2011 6:59 pm
See this post for some relevant discussion.
PostPosted: Wed Mar 09, 2011 8:40 pm
I've got a Holley Red pump mounted under the trunk for my fuel cell.
The pump is louder than the rest of the car. At the dragstrip. Wide open. :lol:
To see if you can live with it, just fire up your weedeater, stick the spinny fish line end out the window, Duct tape the throttle on the weedeater wide open, and go for a drive. Leave the weedeater on your back seat.
The pump makes the same noise whether the engine is running or not.
:lol:
PostPosted: Thu Mar 10, 2011 8:49 am
Not to hijack the thread, but where can you get a good non chinese/non remanufactured mechanical fuel pump?
PostPosted: Fri Mar 11, 2011 11:40 am
I was wondering the same thing, since it seems like a prime reason to contemplate a new electric pump.... Given that the car's first pump lasted several decades, and the NAPA replacement lasted only a half a dozen years, I, too, would welcome a better answer.
- Erik
PS. While we're at it, where can you buy good quality *anything* these days? Distributor caps, brake pads, pumps, you name it... No wait, that's a hijack. ;) Let's start a new thread, if anyone actually has any of those answers.
PostPosted: Fri Mar 11, 2011 12:22 pm
Most often the diaphragm ruptures causing fuel pump to fail. This weakening was a much slower process when we were using pure gasoline.
Now we are suffering from government mandated dilution of motor fuel with alcohol. The alcohol rapidly degrades the soft material a diaphragm is made of. Until an alcohol resistant diaphragm is used, pumps won’t last long. Same goes for soft fuel lines. One has to use the latest fuel injection hose; SAE30R9.
PostPosted: Sat Mar 12, 2011 8:51 am
The last fuel pump I bought was from Auto Zone. Is was Manufactured in Ohio USA. Ill see If I can find the trade name. I had a problem with one under warranty and called Ohio talked with them as to origin USA,WOW. They replaced overnight. :D
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
