It is currently Tue Nov 17, 2026 6:59 am
PostPosted: Tue Mar 15, 2011 8:51 am
Hi All,
In an assembled slant, what metals are capable of coming into contact with the coolant?
I'm interested to know if using a British product (Deox C from Bilt Hamber) would be suitable for doing a 'cold' de rusting flush (without running the engine). I know the fluid is perfectly safe for use with ferrous metal and aluminium, but it does tend to attack zinc, tin and lead.
I so far have iron (for the head and block) and aluminium (for the thermostat housing and water pump), steel (my freeze plugs, various bolts and studs) and stainless steel (the manifold bolts where they enter the water jacket). The thermostat has brass elements but it will be removed. So all looks good so far . . .
Any places where different metals may be an issue? What's the head gasket likely to be made of (installed in the mid 90s)?
1960 Plymouth Belvedere 4 door sedan
Stock 60 225
Push button 3 speed Torqueflite
Right Hooker
PostPosted: Tue Mar 15, 2011 9:28 am
Depending on how old, the radiator will have solder lead,copper,possible brass.
PostPosted: Tue Mar 15, 2011 9:37 am
That is if you plan on flushing the rad too. Also on the older cast blocks they have a higher concentration of nickel. The factory head gasket is likley steel but if replaced (90's) composite.
PostPosted: Tue Mar 15, 2011 10:23 am
Thanks Romeo, great answers!
Yup, just the block/head/water pump are being flushed. I need to remember to take the heater matrix out of the equation too, I guess that's more than likely a soldered brass matrix (aftermarket item I think - right hand drive '60 fullsize can't use the original heater assembly as far as I understand).
High nickel content in the block eh? That may be a cause for concern - I shall have to call up about that.
When you rever to a composite gasket, what are the materials? Is it a graphite/steel type gasket?
Last of all, what's the water pump like for bearing and impellor materials? I believe the impellor is steel/iron?
Stock 60 225
Right Hooker
PostPosted: Tue Mar 15, 2011 2:07 pm
Water pump, steel parts. What about the seal in the pump ? Don't know what it will do to that. Head gasket = Steel core with paper type material on both sides bonded to the steel. Composite may not be the correct word, some have silicone sealing rings for cylinder, water, oil passages.
Just trying to think of things. Freeze plugs in the block may be brass or steel.....
PostPosted: Wed Mar 16, 2011 5:54 am
Sorry to Hijack, Where would the solder be in the radiator?
PostPosted: Wed Mar 16, 2011 6:23 am
solder at all seams in rad and heater core
