It is currently Sat Oct 10, 2026 7:09 pm
 Post subject: Checking valve clearance
PostPosted: Thu Mar 31, 2011 4:34 am
I couldn't find any info on how to check valve to piston clearance so I did my own. Filled the remaining space in 2 cylinders after hitting the top with clay, snugged the head with push rods, turned crank enough times to see the valves move, checked clay. That should be it right :?: (thanks(again)
PostPosted: Thu Mar 31, 2011 8:05 am
Yup, that works. Make sure you do it with the same type of head gasket you will be using in the final assembly.
PostPosted: Thu Mar 31, 2011 6:58 pm
Thanks Dan this is almost getting to be easy. One day I'll be the one giving help.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 18 guests
