It is currently Tue May 19, 2026 4:47 pm
PostPosted: Mon Apr 04, 2011 12:44 pm
Guys have an 8.75 under a 71 valiant I want to use in my 63 dart and the front disc brakes.
Has anyone re-drilled the 8.75 axle flanges for the BBP?
Up front can I swap on BBP hubs and caliper brackets or what?
PostPosted: Mon Apr 04, 2011 12:56 pm
Yes, you can have your rear drums and axles redrilled. Generally screw in studs are used as they don't need as large a hole in the axle.
Which disc brakes? Assuming you have small bolt pattern K-H disc brakes you're stuck using the original calipers, but I would check with Stainless Steel Brakes to see if their dual-bolt-pattern discs will work on the original spindles. Most people wanting big bolt pattern discs use the '73+ stuff.
