It is currently Sat Oct 10, 2026 5:03 am
 Post subject: Pulling engines?
PostPosted: Sun Apr 17, 2011 12:25 pm
I have seen many people ask about where to lift their engines when pulling them out. One of the neat things I kept off the tug is this factory lifting bracket. It bolts right to the two bolts on top of the head and held the engine at the perfect angle for removal. It has a second hole to the rear which I am guessing would be for lifting the engine and tranny as a unit.(Although I have not tried this.) I would be glad to make a pattern for anyone that wants one. Then you could make your own. I would guess it could be made out of 1/2" aluminum instead of steel if you wanted.
I do have a small country metal shop that I deal with here locally. If there was enough interest, I could check and see what it would cost to make some of these up. This would have to wait until after the Mason Dixon race next month for sure. But if there is interest I will check on some pricing.
PostPosted: Sun Apr 17, 2011 1:05 pm
Poser
DadTruck made one out of 3 inch angle iron that works very good. That one is in true slant form - over engineered. :shock: Thanks for the pattern offer that may help some folks out.
Did ya have a chance to drive that thing around the neighborhood before ya scraped her? :D
 Post subject: Lol...
PostPosted: Sun Apr 17, 2011 7:03 pm
I have one that AndyF made...already pulled a few engines with it...and only 1/4 the size...
I think I'd ask for the upward angle to be closer to the head and mouting points, so that weight and gravity don't put an angular force on the head of the bolts already in tension...
PostPosted: Sun Apr 17, 2011 7:56 pm
Car Model: 62 Lancer, 63 D100
I would be interested in making one up. The pattern sure would help. Thanks for the offer.
Bruce
61, 62, 63, 64 Valiants
62 Lancer
64 Darts
66 Barracuda
64 D100
77 Aspen
 Post subject: Lifting bracket
PostPosted: Mon Apr 18, 2011 4:50 am
Rick,
I would be in for one if you get a chance to check on price etc.
Im in no hurry.
Thanks.
rooster
if it has breasts,wheels,or freon it requires constant attention.
PostPosted: Tue Apr 19, 2011 10:45 am
I would be interested in the pattern also.
PostPosted: Tue Apr 19, 2011 5:05 pm
I would be interested in the pattern also, I made some thing simular from a piece of angle iron,, would like to see how far I could trim it back.
thanks
PostPosted: Wed Apr 20, 2011 9:54 pm
Here's a thread from awhile back.The bracket I use is designed for vans but if'n I had an A body with a slant I wouldn't hesitate to give it a try.
http://www.slantsix.org/forum/viewtopic ... t&start=15
PostPosted: Thu Sep 15, 2011 9:13 am
<a href="http://s773.photobucket.com/albums/yy15/1969ron/?action=view&current=sept2011mopargarage67076.jpg" target="_blank"><img src="http://i773.photobucket.com/albums/yy15/1969ron/sept2011mopargarage67076.jpg" border="0" alt="Photobucket"></a> this factory bracket is also shown on allpar.com running in the slants on the engine dyno and in a couple of slants on the overhead assembly line.
PostPosted: Thu Sep 15, 2011 9:15 am
hi, front hole for pulling just engine, rear hole for engine and trans. ron
 Post subject: Sorry
PostPosted: Thu Sep 15, 2011 12:59 pm
Wow, Sorry about this guys. I completely forgot about it. I will try and draw up a diagram with the dimensions on so anyone can make one.
Rick covalt
PostPosted: Sat Sep 17, 2011 8:27 pm
These Little Factory Lifting Brackets are cool & all but I really dont see why they are needed.... when You can just take 2 bolts that go into attatching the bracket to the head and just put your chain on there and lit the engine... Worked fine for me.
PostPosted: Sat Sep 17, 2011 9:36 pm
Ditto. Bolts and chain here too. I can hook the chain short enough to get the motor out of the red car without removing the hood. :D
PostPosted: Sun Sep 18, 2011 6:15 pm
My lifting lug worked real good,50 mil angle in the middle bolt hole. [img][img]http://i905.photobucket.com/albums/ac254/bigall1/mylug.jpg[/img][/img]
Another AP5 valiant still going strong.
Users browsing this forum: Google [Bot] and 7 guests
