It is currently Fri Jul 17, 2026 1:03 pm
 Post subject: Long Front Wheel Studs
PostPosted: Fri Apr 29, 2011 6:14 pm
Car Model: 62 Lancer, 63 D100
It seems that NHRA Tech is cracking down on front wheel shank style closed top lug nuts. Sacramento Raceway is looking for OPEN end shank lug nuts with stud threads showing when using Centerline type wheels.
My problem is I can't find a supplier of 2 1/2" long 7/16x20 front studs for my 64 Dart. I'm still using the stock 9" SBP drums.
Summit has the open end shank nuts but no studs. Help needed
Thanks, Bruce
61, 62, 63, 64 Valiants
62 Lancer
64 Darts
66 Barracuda
64 D100
77 Aspen
PostPosted: Fri Apr 29, 2011 6:27 pm
ARP ??
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Fri Apr 29, 2011 6:53 pm
Dorman and ARP do not show any long studs with a .558" knurl. That is the A-Body front stud size.
62 Lancer
64 Darts
66 Barracuda
64 D100
77 Aspen
PostPosted: Fri Apr 29, 2011 7:24 pm
I'm sure if Bruce gets with them ARP could churn out a set of wheel studs for him,
-Mike
PostPosted: Fri Apr 29, 2011 7:34 pm
Sounds like you'll probably need to buy a big drill bit along with studs having the next larger size knurl.
PostPosted: Fri Apr 29, 2011 8:28 pm
You could always get some threaded rod and screw it into the lug nut so it looks like you have long studs...............
:shock:
PostPosted: Sat Apr 30, 2011 4:02 pm
The rule is that the stud has to extend into the hex part of the open lug nut at least the diameter of the stud. That means that the stud has to be at least 7/16th into the hex, it does not have to extend past the lug nut.
Moroso used to make studs for the small knurl Mopars. :D
 Post subject: Still Does
PostPosted: Sun May 01, 2011 4:03 am
I just installed a Moroso set in my 64 Dart. I had purchased them from Summit a while back, but I'm pretty sure they're still available.
If you can't be good, at least be colorful
PostPosted: Sun May 01, 2011 7:49 am
Found them at Summit after looking for Moroso products.
Thanks for the help.
Bruce
62 Lancer
64 Darts
66 Barracuda
64 D100
77 Aspen
 Post subject: PArt number
PostPosted: Sun May 01, 2011 12:18 pm
Hey Bruce, How about posting the part number? I'm sure it will help others in the future.
Thanks Rick
PostPosted: Sun May 01, 2011 6:02 pm
Moroso and Summit Part # 46160. 7/16"x20 2 7/8" long Press-in
.560 Knurl. 10 for $26@Summit. Moroso states for standard hole size .552-.559. A-Body hole is .558.
I will report back after they are sucessfully installed.
Bruce
62 Lancer
64 Darts
66 Barracuda
64 D100
77 Aspen
PostPosted: Sun May 08, 2011 6:59 pm
Job completed today. On one drum the stock studs just pressed out easily, the other drum studs had been stamp-expanded on the outer drum face side and required grinding the expanded metal off to allow easy press removal. I used a 3" length of 1" galvanized pipe as the hollow stand to press the back side of the stud through. I had to grind a slight angle to the top of the pipe to match the contour of the hub.
The Moroso long studs pressed in smoothly with some grease on the knurl first. They required some extra pressing to straighten them up to fit the Centerline bolt pattern uniformly. Suggest you take a wheel and the sleeve open-end lugs with you to be sure all new long studs are seated properly.
It is comforting to know we are NHRA legal.
Bruce
62 Lancer
64 Darts
66 Barracuda
64 D100
77 Aspen
