It is currently Fri Jun 05, 2026 3:26 pm
 Post subject: 1980 van slant head
PostPosted: Sun May 08, 2011 3:21 pm
Hey all, I was at the junkyard today and saw a slant head from an 80 ram van, but I know that the motor used hydraulic lifters. Could I snag this head and pretty much bolt on to a 71 225? I stole the intake, exhaust and carb from it. Please let me know if these heads are interchangable/somewhat interchangeable, because that head looked good.
The only way you can ever really break something beyond repair is to give up trying to fix it.
PostPosted: Sun May 08, 2011 3:34 pm
1981 was the first year for hydraulic lifters. The '81-'87 heads bolt onto the '80 and earlier blocks, but you have to use the '81-'87 valve cover and if you're keeping your solid lifters you have to use the '80-and-earlier rocker shaft, rocker arms, and associated hardware.
 Post subject: side q
PostPosted: Sun May 08, 2011 6:57 pm
Hey Dan,
Could you point me to that neat article about modding your intake from a 1bbl to two?
Thanks for all your help here.
Jeff
PostPosted: Sun May 08, 2011 7:03 pm
parallel 2bbl setup
Glad to help.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
