It is currently Wed Sep 16, 2026 2:17 pm
 Post subject: Carter linkage
PostPosted: Sun May 15, 2011 11:19 am
Hi everyone. I have a carter 1bbl bbs on my 225 /6 from a 71 valiant. I need the throttle linkage since the previous carb was a holley 1bbl and it hooks up quite different. So does anyone know what the linkage looks like or even a link to a site to purchase it from?
1971 Plymouth Valiant
PostPosted: Sun May 15, 2011 11:33 am
Was the carter BBS stock on a 71? I know my 63 had one (with the shaft-type linkage It had a U-shaped bracket on the end of the throttle shaft that connected to the gas pedal via rods & levers),& I recall once seeing a Rochester 1 bbl on a 68 Dart (throttle cable), but I thought in the 70's A-bodies you only had the Holley 1920 , then later replaced by the Holley 1945 (also throttle cable types). I'd imagine the 2bbl "export" /6 also used a cable, like the later super six.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Sun May 15, 2011 11:34 am
You have the wrong carburetor if the linkage doesn't fit. The linkage is year dependent (and with/without AC on '66 and earlier cars) rather than carburetor make dependent.
PostPosted: Sun May 15, 2011 11:59 am
Yes, the BBS was factory-installed on some 1971 slant-6 engines in passenger cars, trucks, and vans. 1971 was its last year in US/Canada passenger cars, 1974 in US/Canada trucks and vans, later than that in export applications. 1973 was the last year of the Holley 1920, 1974 was the first year of the Holley 1945, and as J. Skinner says, the throttle linkage configuration is mostly dependent on year and application, not carburetor make.
Darrylekg, let's have some photos of the carb you're trying to make work in your '71. Where did you get it?
PostPosted: Tue May 17, 2011 7:18 pm
Hope this is enough to figure it out.
 Post subject: Hmmm...
PostPosted: Tue May 17, 2011 7:42 pm
If the rod linkage bracket could be unbolted from the throttle shaft lever, you might be able to install a stud from another carb (Holley,Carter) so the cable can be attached, or it may require the removal of it and drilling an appropriate hole so a pin can be inserted to hold the cable like the late cars have.
Definately going to take some modification and thinking to make this work and work correctly.
Next most fun question is your car an automatic?
PostPosted: Tue May 17, 2011 9:01 pm
Yep its automatic. So that means the kickdown will be an issue too right?
PostPosted: Tue May 17, 2011 10:19 pm
You're trying to use a '60-'66 A-body carburetor on a '67-up car. Won't work. You might be able to hack it, but it'll be halfassed. Get a correct carburetor for the car; looks like you've got all the right linkage pieces and just the wrong carb.
PostPosted: Thu May 19, 2011 10:49 am
So I pulled apart the Holley 1920 which was on the car previously and was able to swap out the throttle from the Carter. Now everything is bolted up correctly. Worked out pretty good.
PostPosted: Thu May 19, 2011 7:16 pm
Uh…how exactly did you do that? The throttle shaft from a Holley carburetor does not fit on a Carter carburetor.
 Post subject: Lol...
PostPosted: Thu May 19, 2011 7:49 pm
Throttle Lever maybe?
 Post subject: Re: Lol...
PostPosted: Thu May 19, 2011 8:11 pm
Yahbut, that doesn't interchange, either. Neither does the throttle body.
I'm asking for more than curiosity's sake; if the original poster has cobbled it together, it may seem to work OK but could easily fail with catastrophic results (suddenly can't open throttle; car is dead in traffic…can't close throttle, car is an uncontrolled missile…)
 Post subject: ???
PostPosted: Thu May 19, 2011 9:05 pm
I'm curious as well...It didn't look like the rod linkage part could be unbolted from the lever like the 70's Holley 1920 Economaster I have.
That's why I asked as well...
:shock:
PostPosted: Mon May 23, 2011 12:22 am
Sorry I haven't checked this thread in a few days so I didn't notice the new posts. I assure you the way everything was put together on the carb was perfect. The Carter is already on the intake manifold so I won't unbolt it just for pictures sake. But I will take pictures of the new setup from the outside of the Carter and much more detailed pics of the Holley and the pieces missing. I think that should clear it up. Sorry if my wording is choppy I'm posting this with my iPhone. Pics will be up tomorrow.
PostPosted: Mon May 23, 2011 10:34 am
Below is the throttle lever? linkage? (not what it's called) from the carter that I removed.
Here is the side view of the holley with it's parts removed.
And another angle.
The car isn't at my house at the moment so I don't have the pics of the carter as it sits now. I will try to get them taken soon. Hope this helps to clear things up a bit.
Users browsing this forum: Amazon [Bot] and 8 guests
