It is currently Wed May 13, 2026 10:27 pm
 Post subject: Original tire size
PostPosted: Sun Jun 12, 2011 1:36 pm
What was the original tire size for 13" rims?
Thanks.
Tony
1964 1/2 Barracuda
Slant Six 225
(my dream car)
PostPosted: Sun Jun 12, 2011 1:59 pm
6.50 13
About 24.7" diameter and 6.50" total width.
Fit on 13 x 4.5" rim
The radial tire of correct diameter is a 185 80 13 (but it's wider).
The 185 tires are very hard to find now.
Best bet is to goto 14" rims.
Use a 185 75 on the 14 x 4.5 and
195 70 or 205 70 on the 14 x 5.5.
PostPosted: Tue Jun 14, 2011 7:32 am
If you don't want to change rims, Coker Tire still carries 13" tires in both 6.50-13 and P185/80R13 sizes.
PostPosted: Tue Jun 14, 2011 9:48 am
Well I found a 175/70/13 at Pep Boys. 4 tires mounted and balanced only 255.10!
Tony
1964 1/2 Barracuda
Slant Six 225
(my dream car)
PostPosted: Tue Jun 14, 2011 10:12 am
Did you consider that those are 2" shorter than original?
PostPosted: Tue Jun 14, 2011 11:24 am
You would need to switch from a 17-tooth speedometer gear to a 19-tooth gear to keep your odometer & speedometer accurate with a P175/70R13 tire.
Tire Upgrades
PostPosted: Tue Jun 14, 2011 11:48 am
I have no idea how to do that. How much difference could it really make?
Tony
1964 1/2 Barracuda
Slant Six 225
(my dream car)
PostPosted: Tue Jun 14, 2011 12:41 pm
Using the P175/70R13 tire should make your odometer record about 11% more miles than actually traveled. At an indicated 60 mph you would actually be traveling at about 54 mph (if your speedometer was still within calibration).
PostPosted: Tue Jun 14, 2011 2:47 pm
Well that is the closest tire I can find. I guess reading a little slow is better than reading a little fast. At least I will never get a speeding ticket.
I would not even begin to know how to adjust my speedo.
Tony
1964 1/2 Barracuda
Slant Six 225
(my dream car)
PostPosted: Tue Jun 14, 2011 3:49 pm
You will need to install a different speedometer drive gear, (19 tooth) at the other end of the cable, where it goes into the tailhousing of the transmission.
PostPosted: Tue Jun 14, 2011 4:44 pm
Where would one get such a thing?
Tony
1964 1/2 Barracuda
Slant Six 225
(my dream car)
PostPosted: Tue Jun 14, 2011 7:19 pm
I got my 16-tooth pinion gear from Brewer's Performance.
PostPosted: Tue Jun 14, 2011 7:32 pm
You still have the original trans in the car? If so it's a different gear than the '66+ models. The selection for the earlier speedometer drive gears is more limited and they cost more.
PostPosted: Tue Jun 14, 2011 9:03 pm
It is the 727 that came with the car originally.
Tony
1964 1/2 Barracuda
Slant Six 225
(my dream car)
PostPosted: Tue Jun 14, 2011 9:07 pm
So is this what I need?
http://www.brewersperformance.com/prodd ... ?prod=SP19
Tony
1964 1/2 Barracuda
Slant Six 225
(my dream car)
