It is currently Thu May 14, 2026 12:41 pm
Post new topic  Reply to topic  [ 67 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Fri Jun 17, 2011 7:25 pm
points gap
Not on a '73, which has electronic ignition.
check rockers..working properly w/valve cover off..visual inspect../pushrods /bent/ wrong adj gap can increase comp.
Already stated multiple valve adjustments
any intake leak
Nope. :-(
Thanks for ideas, tho.
PostPosted: Fri Jun 17, 2011 7:26 pm
OK- here is my dose of FABO advice-
Slant sixes never run right! The best way to fix your pinging is to swap in a 440!
:roll: :wink:
 Post subject: 440
PostPosted: Fri Jun 17, 2011 7:30 pm
That is good advice. Everyone know that a 440 gets better gas mileage than a slant 6 anyway! :lol:
Good luck Dan!
Rick
PostPosted: Fri Jun 17, 2011 8:00 pm
draging brakes?
or non working oil pressure to pistons
slant six's RULE!
http://www.usajon.com
PostPosted: Fri Jun 17, 2011 8:39 pm
draging brakes?
No, and no.
PostPosted: Fri Jun 17, 2011 8:43 pm
You probably checked the PCV and vacuum advance?
PostPosted: Fri Jun 17, 2011 9:21 pm
Yes -- all of that. It's not a simple routine case of ping caused by faulty state of tune. It's internal to the engine. I'm trying to figure out the mechanism, is all.
PostPosted: Sat Jun 18, 2011 9:57 am
What do the plugs look like?
Compression test?
Leakdown test?
Vacuum readings?
Litres of oil per 1000kms?
valve timing map?
......or are we just going to guess?
PostPosted: Sat Jun 18, 2011 11:13 am
have you taken off the valve cover started , let idle and observed..look/listen?
I just did that to adj my valves on our 1968..nice show !
slant six's RULE!
PostPosted: Sat Jun 18, 2011 11:51 am
points gap
I know this is a dumb question, but do all 1973s have electronic ignition? :roll:
PostPosted: Sat Jun 18, 2011 12:12 pm
Electronic ignition was standard equipment in 1973. I do not believe it was a delete option. If so everything was built with electronic ignition.
PostPosted: Sat Jun 18, 2011 12:41 pm
Looks like it. Don't look like we're much into reading the question, either!
PostPosted: Sat Jun 18, 2011 1:45 pm
Since we're guessing, Grapes! Gravy! Very small rocks!
Sorry, I couldn't resist the Monty Python reference since we are taking about the machine that goes PING!
Seriously though, it sounds like Dan has investigated all the possible causes of spark knock/preignition. I think this will wind up being an odd internal mechanical problem. That much timing chain slack on a motor with under 60k miles is unusual. I am going to bet a dollar the that problem will wind up being something like loose connecting rod cap bolts allowing the piston to rattle a bit or a loose wrist pin allowing some piston slap to happen, or an exhaust leak.
PostPosted: Sat Jun 18, 2011 2:43 pm
Pebbles in the hubcaps.........
PostPosted: Sat Jun 18, 2011 3:21 pm
If you replace the engine and it still has the ping... run away, very fast.
:D :D :D :D :D
Users browsing this forum: Bing [Bot] and 5 guests
