It is currently Fri Oct 09, 2026 8:10 pm
 Post subject: spark plug xperts
PostPosted: Mon Jun 20, 2011 12:51 pm
I bought these say 500 miles ago. Drive very hard @ times..I just asked the local auto store for slant six plugs autolite 66
stock 1968 slant six engine ...they look lean
Uploaded with ImageShack.us
slant six's RULE!
http://www.usajon.com
PostPosted: Mon Jun 20, 2011 1:00 pm
Jon, that washer has to be removed, and yes, that plug looks like you are running on the lean side.
What carburetor and jet are you running?
It looks as if you have a peanut head.
Which cylinder did that plug come out of?
PostPosted: Mon Jun 20, 2011 1:09 pm
Modern gasoline doesn't tend to color plugs as in decades past so I'm not worried about the plug being white. The side electrode doesn't appear heat damaged, but it shouldn't be at this power level. The spots on the side electrode. Are they hard or powdery?
PostPosted: Mon Jun 20, 2011 1:19 pm
that plug came from 4th cylinder back from the front of the engine. i removed the washer with dykes. it was a tad bit of a chore..this is the 2nd plug back from the front of then engine. i took two pics of it..Josh the spots r hard.
slant six's RULE!
PostPosted: Mon Jun 20, 2011 1:35 pm
3rd plug back
slant six's RULE!
PostPosted: Mon Jun 20, 2011 3:42 pm
Try a set of NGK ZFR5N (stock number 3459) instead of that Chinese-made Autolite junk. I don't see too much to be concerned about in these pics you're showing us. Looks as if these plugs were running with the washers, which will tend to make them run hotter.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 10 guests
