It is currently Mon May 11, 2026 12:48 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
 Post subject: Neutral safety switch
PostPosted: Tue Jun 21, 2011 11:36 pm
Is there anyway to remove the neutral safety switch without having all the transmission fluid pouring out?
PostPosted: Wed Jun 22, 2011 1:26 am
Not that I know of, it's a big hole so there will come a lot of fluid out of there in a short time, you can use something to plug the hole but alot of fluid will come out anyway even if you are very quick doing it.
PostPosted: Wed Jun 22, 2011 9:03 am
Jack the back end of the vehicle way up so all the fluid runs to the front of the transmission?
PostPosted: Wed Jun 22, 2011 12:32 pm
Reed's got the right idea: jack the car up and support it properly in such a way that the fluid runs away from whichever part of the transmission you're working on. So you'd want to jack up and properly support the left side of the car. Put it at as much of an angle as you can safely do to minimize leakage. Or else just resolve that now's a good time for a fluid and filter change!
PostPosted: Wed Jun 22, 2011 1:00 pm
Aww, where's your sense of adventure Dan? Just kidding. I assumed that anyone who was going to be jacking a car up and crawling underneath would have the good sense to block the front wheels and properly support the rear with jack stands.
However, I second the motion to just do a fluid and filter change, and maybe a band adjustment while you are in there.
 Post subject: ?
PostPosted: Wed Jun 22, 2011 1:57 pm
If you had a real sense of adventure you'd just do it on the fly! How much fluid can it leak if your fast!! :lol: :lol:
PS Don't wear clean clothes when you do this! Aw, and a picture when your done. :lol:
Rick
PostPosted: Wed Jun 22, 2011 2:07 pm
I actually have replaced the neutral start switch and even the speedo gear in a fully loaded auto tranny that was installed in a vehicle and that was flat level. Not much fluid leaked out at all. The bigger issue is clearance between the floor pan and the switch. There is very little working room.
PostPosted: Thu Jun 23, 2011 8:16 pm
So it turns out my garage doesn't have all the space in the world, which means that jacking the car up in such a way that the fluid won't spill is completely impossible.
So I just resolved to removing the switch and plugging it with a balled up plastic bag. Just a few drops were spilled and the switch was replaced.
The funny thing? Still no back up lights.
PostPosted: Thu Jun 23, 2011 9:59 pm
What year/model car?
PostPosted: Thu Jun 23, 2011 10:35 pm
'69 Dodge Dart Swinger. Automatic with the shifter on the steering column.
PostPosted: Fri Jun 24, 2011 5:58 am
With key on, check and see if you have approx 12volts on one of the end wires (not the center wire)of the neutral safety sw connector. If you do, jumper the two end wires of the connector, and see if your BU lites come on. If they come on the problem is either the switch or the Part inside the trans that pushed the switch. If they donot come on the problem is either bad bulds, or the wire from the switch to the socket, or a bad groundat the socket.
If you do not have 12 v at the connector, the problem is between the fuse block and the connector. EI, blown fuse, bad connection at the bulkhead connector, etc.
PostPosted: Sat Jun 25, 2011 2:51 am
So jumper the two outside connectors from the female connector, right? What should I use? Would a paper clip work?
PostPosted: Sat Jun 25, 2011 3:59 am
That is correct. A paper clip should work just fine. Make sure it is not one of those color coated clipe. Must be a plain one.
PostPosted: Mon Jun 27, 2011 12:50 am
So yea, they didn't come on. I know the wires from the bulbs to the front are fine, but I'm not sure about the rest.
PostPosted: Mon Jun 27, 2011 3:39 am
Do you have 12 volts on one of the outside connector terminals?
