It is currently Mon May 25, 2026 12:03 am
 Post subject: Subframe removal
PostPosted: Sun Aug 07, 2011 4:18 am
Hi Guys,
I guess this is the section to post in, doesn't really fit anywhere else.
I've got some rust repair to do on my car, and I think I may need to do a bit on the subframe box section (upper surface). To do this I'll have to drop the subframe.
How easy/difficult is this to do? Can you keep the engine mounted to the subframe? I reckon I can repair the top surface of the subframe if I have around 15" of clearance between it and the body.
How about putting it back together again? I won't be doing this for a while so just trying to get an idea.
Any help/advice etc is greatly appreciated.
All the best,
60 Ply
1960 Plymouth Belvedere 4 door sedan
Stock 60 225
Push button 3 speed Torqueflite
Right Hooker
PostPosted: Wed Aug 10, 2011 1:49 am
Nobody done this?
1960 fullsize cars had a bolt in subframe at the front, I don't know if it is the same with the Valiant/Lancer over the next few years. Can anyone comment on the smaller cars?
Stock 60 225
Right Hooker
PostPosted: Wed Aug 10, 2011 5:47 pm
If you are talking about an engine K-frame, then yes, the smaller cars have them too.
Buddy of mine made a dolly that he dropped the engine, trans, and front suspension out of a Barracuda as an assembly.
Not sure how much you can lower it out without removing the engine.
I used to take the K-frame out of my Dart and leave the motor in, supported on blocks.
PostPosted: Wed Aug 10, 2011 6:44 pm
You will want to soak those bolts for a week before trying a wrench on them.....
If they wont start to turn and bugger up the nut holders you will be forever sorry.
PostPosted: Thu Aug 11, 2011 2:49 am
Not sure if a K member is the same thing - I understand them to be like the front cross member.
I'm talking about this thing : http://postimage.org/image/glx3js2s/
I might be getting lost in translation though.
Stock 60 225
Right Hooker
PostPosted: Thu Aug 11, 2011 6:49 am
The K member is a more abbreviated version of your sub frame.
The picture you posted looks rather like a later B body subframe.
PostPosted: Thu Aug 11, 2011 7:11 am
It was just a picture I managed to find of a mopar subframe. Mine's probably a little different.
The rust problem I've got is on those fore-aft box sections. It's on the top surface nd I need to cut it out and replace it. I think the original structure was two channel sections lap welded together to form the box. Where it's rusty I'll hack it out ond replace with a single thicker piece to get rid of the lap joint.
Any idea what gauge steel these originally were?
Stock 60 225
Right Hooker
PostPosted: Thu Aug 11, 2011 8:47 am
You might check with AutoRust to see if they have anything that might help or inspire.
