It is currently Thu May 28, 2026 4:15 pm
PostPosted: Wed Aug 31, 2011 9:41 pm
has anyone ever used nylon locknuts on the uca eccentric bolts? it seems like these would keep the alignment from coming out of wack if you tap a curb a bit too hard.
70 Plymouth Valiant 4dr
PostPosted: Thu Sep 01, 2011 5:51 am
Lockwashers handle that. I've never had trouble with this. If you like extra insurance, go for it!
PostPosted: Mon Sep 05, 2011 7:39 pm
The only time I see alignment out of wack after "tapping a curb a bit too hard" is because something is bent. If the uca cams move then they weren't tightened to spec.
63 Valiant Wagon
225 - 4 bbl
