It is currently Fri May 15, 2026 2:00 pm
 Post subject: Pertronix plug gap?
PostPosted: Sat Sep 10, 2011 6:37 pm
What plug gap are you guys using with your pertronix unit?
PostPosted: Sat Sep 10, 2011 7:20 pm
0.035" (stock) worked best on my '64 w/Pertronix. I don't think I'd go larger than 0.040". It's better than points, but it ain't HEI or MSD.
PostPosted: Sat Sep 10, 2011 7:44 pm
i think mine liked .037...
with the ign II and blaster II coil
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sat Sep 10, 2011 7:53 pm
Right now I think it is set at .035 and it runs fine, just seeing if it can run better! I have the HEI/Blaster 2 in my truck and the Pertronix/Blaster 2 in Nikki 66 dart and think that I get a little better spark from the Pertronix.
PostPosted: Sat Sep 10, 2011 11:48 pm
I'm using a pertronix 1
pertronix 3 ohm coil
Low resistance spiral metal core plug wires (borq-warner lifetim warranty)
and
Autolite extended tip 985 plugs.
gapped at .044
Runs great, no misfires.
PostPosted: Sun Sep 11, 2011 3:17 pm
I picked up a new cap, B&W wires and a set of NKG "Jeep" plugs (the long ones). I will have Nikki gap them at .037 when she gives the 66 a tune up tomorrow and we will see how it works.
Users browsing this forum: Google [Bot], volaredon and 4 guests
