It is currently Sun May 24, 2026 1:29 am
Post new topic  Reply to topic  [ 1346 posts ]  Go to page Previous 127 28 29 30 3190 Next
PostPosted: Fri Aug 19, 2011 2:11 pm
Greg, great documentation as always!
I gotta ask why you still have the front quarter panel Valiant 100 emblems, and turn signal lights on the car. Must be almost half a pound right there!
:wink:
Brian
'Cause I like them.. I cant remove stuff I like now...
Maybe I will put 3 Marker Lights and 2 Emblems on the RR quarter for better weight Distrubition....without getting rid of the stuff I like :-)
PostPosted: Fri Aug 19, 2011 2:13 pm
Glamour NO!!!! BITCHEN YES.Ya know I love it.Isnt doing this kind of stuff the most rewarding?It is for me.Guzzi Mark
I know you love this mark!
Hey it's rewarding but possibly not as much as picking up .12 by adding 4* timing - Now that was easy! :shock: :D :o :lol: 8)
PostPosted: Sat Aug 20, 2011 9:18 pm
Now you have me really thinking.I run 28 and havent really played with it much,I have a dial back in car that I retard to about 15 for starting,then dial it to a stop I put on it at 28.My cam and combo is different,but it would bee easy to pull my pin stop and try running 30,then 32.Thats as far as I could go without moveing dist.Ya got me thinking.My gut feeling is my car is going to like the 28 the best.Guzzi Mark
PostPosted: Sun Aug 21, 2011 7:17 am
On my stuff the dyno doesn't show any HP gains from running over 28 degrees but that doesn't mean that on the track a few more degrees couldn't be benefical, especailly in the lower gears. Time slips trump dyno readings every time. I have been using an MSD three stage retard with a switch on the shifter that retards 2 degrees in high gear so I am running 30 degrees in first and second and 28 in third. I try to run a conservative set up, a little less timing, a little less compression, a little rich but Mark is pushing me. You are doing good work Greg.
PostPosted: Mon Aug 22, 2011 11:55 am
Cool. Good to know Seymour... I think that my Combo Might like a bit more timing So we'll see.. I am going to fiddle with in and of course post the results. :-)
PostPosted: Thu Aug 25, 2011 8:25 pm
Well after fiddling with the timing a bit more My engine seems to like 34*
And with slightly worse air than 2 weeks ago (About .25" of mercury Less on my barometer)
I was able to set at least 4 new personal best records. (not all on the same Run)
1.80 60'
8.08 1/8th
12.69 1/4
106.xx 1/4 MPH
I will have to scan and post the Timeslips a bit later.
CLICKY TO WATCH VIDEO OF THE 12.69 RUN! Against another gold 4 door mopar :-)
PostPosted: Fri Aug 26, 2011 4:44 am
Congrats, Greg! I wonder if your timing marks are accurate? 34 deg is a lot, but who knows.
Better converter and you'll be knocking on Gary Bruner and Ron Parker territory!
PostPosted: Fri Aug 26, 2011 5:57 am
Good job Greg, you have to be pleased with a 12:69!! There are alot of big tire cars that don't run that quick with a V8. What stall is your convertor?
All that metal dieting & tuning is really paying off.
Keep digging.
Derek
70 Duster 238'', four speed ,3:91's, 500 Elde, Hookers
68 Dart 4 dr 225, completely original
PostPosted: Fri Aug 26, 2011 9:20 am
Keep digging.
Derek
Thanks Derek,
The converter is supposed to be 3500, but it is one of the issues now.. I just think that it does not stall that high, another one (that is Looser) is in the works and will be installed when time allows.
PostPosted: Fri Aug 26, 2011 12:51 pm
Poser
Thanks for the video Greg! Before I knew what I was doing I was yelling at the screen. My wife had to check on me to see if I was alright. 12:50's before ya know it!!!!!!! :D
 Post subject: Timeslips From 8-25-11
PostPosted: Mon Aug 29, 2011 2:02 pm
Wayne, I dont Know what to say Hopefully you just got a bit of slant sickness!
:D
Here are the timeslips with 4 new Personal Best Times on them ! YAY!
Also in the Works is a graphic Treatment for the sides of the car - Taking the 70's duster Script and Copying the "R" at the end of duster and adding it to the beginning in place of the "D" it will be a true 1968 Plymouth RUSTER!.
 Post subject: September 2011 Update
PostPosted: Sat Sep 10, 2011 10:10 pm
I visited TNT again this week, and the car Runs pretty consistient in the 12.70-12.78 Range and Also 1.8X 60' Times.. At either 105 0r 106 MPH.
I did Best My previous 60' Time of 1.80 now it's 1.79..
Also I found the Timesilps From the First 4 runs with Ruster Back in 2009.. With the Stock 1 BBL Slant! :-)
Ruster is In the Right lane with a sloooooooooow 19.1-19.3 Times
PostPosted: Sun Sep 11, 2011 6:38 am
Gooed job Greg! You've really got that thing flying. :D
PostPosted: Sun Sep 11, 2011 7:53 am
Thanks dennis, I am doing what I can now...... Hey if you can make it
to clay city, ypu can see ruster in person :wink: :wink:
 Post subject: Graphix Attax
PostPosted: Thu Sep 22, 2011 6:44 pm
Well I finally Got the Graphics For Ruster Complete...
I need to either get an LCD Projector or Copy it onto an overead Transparency and then Project it on the door of ruster and Start Tracing & Painting..... I will Not have this done For clay city... But next spring should be a good date for this Modification..
I will be unable to hit any Test n tunes before I leave for clay city... So I am ready & excited to go!
