It is currently Fri Oct 09, 2026 9:43 pm
PostPosted: Wed Sep 14, 2011 11:40 pm
Ok, so I ordered one of summits universal street/strip aluminum radiators to replace the one in my car. It's a crossflow, 22" wide x 19" tall x 2.25" thick. I was wondering what people have done/recommend for mounting an aftermarket radiator. I was thinking 4 L brackets with rubber and bolt it to the radiator support top and bottom on each corner.
Thanks,
Seth
Annabelle: 1970 Dodge Dart Hardtop
1991 Nissan 240sx (sileighty) Lots of mods
1974 Dodge Dart *Wrecked*
PostPosted: Wed Sep 14, 2011 11:58 pm
Got a picture of the radiator?
PostPosted: Thu Sep 15, 2011 12:26 am
Not yet, it comes in tomorrow afternoon. I'll get some pictures of it outside the car and mocked up in the car
PostPosted: Thu Sep 15, 2011 12:34 am
Does summit have pictures?
PostPosted: Thu Sep 15, 2011 12:57 am
Yeah, link: http://summitracing.com/parts/SUM-380324 I am using my phone right now, so if for some reason the link doesnt work the part number is at the very end
PostPosted: Thu Sep 15, 2011 2:15 am
Looks like you support it from the top and bottom.
I'd use angle aluminum or plate aluminum (home depot) that attaches along the whole length of the radiator, then attach to the top and bottom of the opening. Whatever works best.
The aluminum will also act as a wind stop so air has to go thru the radiator.
You could rubberize it too.
PostPosted: Thu Sep 15, 2011 6:43 am
Looks like this is what Summit offers..... http://www.summitracing.com/parts/SUM-380100/
Shouldn't be too hard to fab something like that yourself. I think I might coat them with plasti-dip or something like that, just to prevent wear spots.
Mike
An officialis Tyrde-Browne Racing membrum
PostPosted: Thu Sep 15, 2011 10:34 pm
Okay, here is a complication, kinda. First off it looks great in the car and fits great, except for the opening in my radiator support is a tad too big side to side, its got clearance on either side of the tanks, should I bolt on something here to deal with that? these are what I think I'm going to mount the radiator to the support by, its metal flanges on the top and bottom of the core, I'll take a picture of it in the car tomorrow:
PostPosted: Fri Sep 16, 2011 6:02 am
I would recommend closing off the extra openings. If you don't it will be an area where air can go around the radiator instead of through it.
Should be able to do so with a couple pieces of sheet metal/aluminimum.
Mike
PostPosted: Fri Sep 16, 2011 8:36 pm
Got it all mounted up! Thanks for the input. I'll upload some pictures of it tomorrow, it looks great!
PostPosted: Sat Sep 17, 2011 12:14 pm
Pictures
I used a couple "L" brackets from my local hardware store along with some thick red rubber plumbers gasket. I used a bolt and 3 nuts so I bolted the bolt to the bracket, then drilled a hole in the radiator support, then I had a nut on the top side of the support so I can change the pitch of the bracket for more or less clamping force, then I put a nut on the bottom of the support, so far its effective, the radiator doesn't move at all.
I do need a new upper radiator hose though :?
PostPosted: Sat Sep 17, 2011 2:41 pm
Ya im thinking an A body V8 hose would do the trick,maybe one from an A/C car would be best.
PostPosted: Sat Sep 17, 2011 3:24 pm
You could also install a straight (V8) water outlet that would point towards the driver's side rather than towards the sky, thus shortening the top hose's route considerably.
PostPosted: Sat Sep 17, 2011 3:36 pm
Thank you Dan! I would have never thought of that!
PostPosted: Sat Sep 17, 2011 6:29 pm
I got mine at NAPA. :wink:
Users browsing this forum: Bing [Bot] and 6 guests
