It is currently Tue Jun 23, 2026 2:09 am
Post new topic  Reply to topic  [ 28 posts ]  Go to page 1 2 Next
 Post subject: heat control valve
PostPosted: Tue Aug 11, 2009 5:50 pm
my 1976 225 has a heat control valve that does not seem to be working. when it fails (no spring tension) does it fail closed or open? it has a weighted disk sticking out from the manifold.
thanks
jd
PostPosted: Tue Aug 11, 2009 9:48 pm
It fails in the open position somewhat most of the time. Make sure that it is moving freely. They can rust and stick.
1979 W150 Shortbox
225, NP435, 9 1/4, Dana 44
The Good Life.
PostPosted: Tue Aug 11, 2009 10:45 pm
PostPosted: Tue Aug 11, 2009 11:23 pm
I found a picture of mine... I think counter-clockwise, looking at the counter weight from the front of the car, blocks the heat to the intake and would be the most free running for the exhaust.
Danny
PostPosted: Wed Aug 12, 2009 5:24 am
thanks for the replies. it does move freely, i guess i will just let it be for now, the car is running well.
thanks
jd
PostPosted: Sun Sep 11, 2011 3:34 pm
Is this also the case with earlier (63) riser valves? Mine is clearly not working, and I need to be sure that pushing it counter clockwise ensures that the exhaust is as free flowing as possible.
Thanks!
PostPosted: Thu Sep 15, 2011 2:23 pm
Mine is also not working, and no one (the Dodge dealer, Napa auto parts, etc.) can seem to locate a rebuild kit, and all the slant sixes are gone from the pick your parts around me. I have a 67 with the square weight (as opposed to the later years ound weight). If I am standing at the bumper in front of the car and looking toward the windshield and at the engine, it will be in what position if i turn it clockwise? so the top of the square moves toward the driver side? I know it only turns about 1/4th of a circle, but I want to make sure that in my situation in southern california, it is not sending hot exhaust to the intake.
Thanks!
PostPosted: Thu Sep 15, 2011 3:00 pm
6 Pack Dart
Try putting "PB Blaster" on the shaft where it enters the manifold, let it set for a while, then tap gently with a small hammer one end then the other. This may let the shaft move much more freely. :idea:
Richard
PostPosted: Thu Sep 15, 2011 4:43 pm
thank Richard. I got it to move, but now I need a new spring. Until I can find one, without taking the intake off, I cant tell which way keep the exhaust going down and not up to the intake. I even looked in the service manual, and there is no diagram to show which way is closed and which way is open. Do you know?
PostPosted: Thu Sep 15, 2011 5:19 pm
6 Pack Dart
Rotate the shaft (looking at it from the front of the car) counterclockwise.
Richard
PostPosted: Thu Sep 15, 2011 5:27 pm
Richard
Beat me to it , counterclockwise on the counter weight closes off intake heat :D
Kevin
crossthreads are better than locktite
PostPosted: Fri Sep 16, 2011 6:08 pm
Thanks guys. And the flap inside didnt change when they changed the weight from square to round? Because my mechanic though it was the other way around (with the weight clockwise) - any ohotos by any chance? I tried to find a slant six at the pick a part, but no luck and I really dont want to have to take anything apart.
PostPosted: Fri Sep 16, 2011 7:11 pm
6 Pack Dart
Please trust us ! Don't make me have to do a video of both types of counter weights just because your mechanic thinks otherwise. :roll: :lol: :lol:
Richard
PostPosted: Fri Sep 16, 2011 7:38 pm
The flap changed a little -- its shape was altered -- but the way it works is the same.
PostPosted: Fri Sep 16, 2011 8:37 pm
Sorry! I just wanted to make sure, because he rotated it clockwise and wired the valve to the post, he said it was the reason the engine was running hot. But that would mean that he wired it OPEN to heat the Intake, right? Not closed... The other way (counterclockwise) would prevent it from heating the intake... If I could have found a rebuild kit, or even the newer style of valve, I would just rebuild/replace it, but no one has them any more.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
