It is currently Sat May 23, 2026 10:52 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Thu Sep 22, 2011 6:50 pm
I went out and bought a decent torque wrench at Pep Boys. Then I warmed up the engine, shut it off, and tightened the head bolts to 75. I did it in two passes, going to 70 first. I was shocked at how far the bolts turned. Then I started it back up and set the valves. There is no doubt it is running smoother now.
I think maybe I killed my O2 sensor by letting it idle in the garage for so long. When I took it for a ride, it was yielding ridiculous AF ratios which I did not believe at all. It showed way rich. I will post about this in the fuel injection section.
Thanks all.
Sam
PostPosted: Thu Sep 22, 2011 6:57 pm
Arp studs,I go to 90.cold.Will warm it up a little next time before the spray and might try 95.Mark
PostPosted: Fri Sep 23, 2011 6:44 am
Drove the car to work this morning, and the engine is so smooth now. I imagine the valve adjustment was the big thing, but the exhaust sounded more even after re-torquing the head, even before I readjusted the valves. It feels like a new car. Don't put this service off.
Sam
PostPosted: Fri Sep 23, 2011 8:36 am
Relevant info, thanks. I had a bolt by cyl. #5 go loose twice.
Olaf.
If I see something like this... I replace the bolt and look carefully for possible cracks.
PostPosted: Fri Sep 23, 2011 7:10 pm
Thanks again, will do!
Olaf.
Aspenized
Users browsing this forum: Google [Bot] and 10 guests
