It is currently Wed Oct 14, 2026 4:49 am
 Post subject: valve adjustment
PostPosted: Sun Oct 02, 2011 10:40 am
I'm a newbie to slant six motors and overall mechanic. I've followed alot of recommendations from this site and have done some work on my slant six. So I pulled the valve cover off of my 1986 dodge d100 and was ready to do a valve adjustment and to my surprise I couldnt find an adjustment screw or bolt to adjust my valves. Am I missing something or are these valves non adjusting?
http://i120.photobucket.com/albums/o164 ... 1020_1.jpg
1986 Dodge D100
PostPosted: Sun Oct 02, 2011 10:53 am
You have an hydraulic valve train. The earlier engines are mechanical.
Guido
PostPosted: Sun Oct 02, 2011 11:20 am
Welcome on the board. Slant-6 engines starting in 1981 had hydraulic, non-adjustable valvetrains.
PostPosted: Sun Oct 02, 2011 1:35 pm
Cool thanks! I had rough idle and it shuts off every once and a while. So i guess my next move is to look at the carb?
1986 Dodge D100
PostPosted: Sun Oct 02, 2011 3:39 pm
If I were you, my next move would be to determine f the vehicle had one of the notorious "lean-burn" systems on it. The Lean Burn systems used by Chrysler in the 80s are notoriously failure prone.
PostPosted: Sun Oct 02, 2011 8:14 pm
I'll check it out and see if the lean burn is installed. Thanks.
1986 Dodge D100
Users browsing this forum: DuckDuckGo [Bot] and 11 guests
