It is currently Thu May 21, 2026 3:24 am
What fuel mileage do you get in your slant?
17.0 to 17.9 35%  35%  [ 8 ]
18.0 to 18.9 9%  9%  [ 2 ]
19.0 to 19.9 17%  17%  [ 4 ]
20.0 to 20.9 9%  9%  [ 2 ]
21.0 to 21.9 4%  4%  [ 1 ]
22.0 to 22.9 17%  17%  [ 4 ]
23.0 to 23.9 9%  9%  [ 2 ]
Total votes: 23
 Post subject: Fuel Mileage Poll
PostPosted: Sun Oct 09, 2011 10:25 am
What kind of fuel mileage is everyone getting from their slants?
PostPosted: Sun Oct 09, 2011 10:51 am
Might be interesting to mention a little about your set up, carb, cam, gearing, distributor work, vehicle, etc.
PostPosted: Sun Oct 09, 2011 2:00 pm
i get about 20mpg out on the road...
225 bored .080
heavily ported head (10:1 comp)
.475 lift / 246 2 50 cam
headers,clifford intake, 600dp holley
3500 stall converter
8.75 with 3.91 sure grip, 28" tall tires
cruize at 63mph @ 3100 depending on the hills
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
 Post subject: Fuel mileage
PostPosted: Sun Oct 09, 2011 2:06 pm
I posted the lowest I get (22 - 22.9) due to all the local driving I have been doing. Mostly short hops of 4 to 8 miles and an occasional 16 miles run with no freeway driving.
Currently I am running a bone stock 1979 engine that had been sitting in a barn for 10 years which was covered in hay missing the carb, fuel pump, distributor and dipstick for $125. I installed it as is, filled it with Mobile 1 0-30W synthetic oil and have been driving it the last few years while my good 9.5 to 1 engine gets some upgrades.
As far as set ups I run the SL6 hot. 195 degree stat and a stock 18" wide radiator with a 16 pound cap. Quick warm ups are a must. The intake must warm up quickly and stay warm. I do not run a stock fan which blows on the intake constantly. Instead I run two electric fans which rarely turn on unless I am in traffic. The second item is the heat deflector which also keeps the intake manifold warm. I was lucky to find a Holley 1920 Economaster from a taxicab which atomizes much better at low rpms. I also run a very fast distributor curve which makes the SL6 feel like there is more power. It stops at about 52 degrees advance. To keep it from pinging I run colder UR4 NGK plugs. As a result I don't have to push it very hard since it is so punchy and peppy.
My car is a 74 Dart Swinger (heavy 3300 lbs.) with a 2.76 ratio 8 3/4 Sure-grip.
The exhaust is mostly 2.5" running a Flowmaster 70. At the manifold it starts out at 2.25" for a few feet then steps up to 2.5".
Tires are 26" tall Toyo Eclipse P215 70R series. Transmission gear in the 904 is a 28 tooth. Cruise at 50 mph is 2000 to 2200 rpm, 2500 at 60 mph.
PostPosted: Sun Oct 09, 2011 6:13 pm
18.3 mpg, 62 valiant, 170, was parked for 22 years, haven't done a tune up yet.
Dave
1972 d-100 parts truck
PostPosted: Mon Oct 10, 2011 5:33 am
225 ci, 0.030â€￾ over, compression 9.5:1, 3-8â€￾ vacuum at 650 rpm. – 18â€￾ vacuum @ 4500 – 5500 rpm
Cam of unknown manufacture; Exh. & Int. .480â€￾ lift at valve – tappet lift .236â€￾ at 0.050â€￾ overlap @ 0.050â€￾ 20* as measured from degree wheel.
Peanut Head; ported, 1.44â€￾ – 1.70â€￾ valves, shaved 0.075â€￾, Clifford intake & headers, 2â€￾ duel exhausts to bumper.
Holley 390; 57 jet, 2.5 PV, Acl. Pump #25 nozzle- orange - #2 hole, brown secondary spring.
904, V8 rated stall @ 2600 rpm
3.55:1 8 ¾â€￾ Suregrip, P205/70R-14
Gutless below 3000 rpm. Pulls like a MF above 4500. She's a former Drag Queen...
17 mpg
PostPosted: Mon Oct 10, 2011 9:22 am
I just checked this out Friday when I made a bomber mission to and from Sacramento.
1967 Plymouth Valiant two-door 225 2 bbl / 4 speed / 3.23 8 1/4
I got 22.xx MPG turning 3200 rpm pretty much the whole way! :shock:
Need to get an overdrive into this thing and fix the seeping gas tank and it should go up more!! 8)
Scott - waywardgarage.com
Why is the rum always gone? Image
 Post subject: 63 valiant wagon
PostPosted: Mon Oct 10, 2011 9:47 am
I get 20 mpg city and 23 freeway ( fast in California) with my super six setup,ei, re-curved dizzy and 2 1/4" exhaust in my 63 wagon.
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Mon Oct 10, 2011 10:03 am
Site Admin
Made seven passes at Redding. Used 1-1/2" - 2" of 110 Purple out of the 8 gallon fuel cell. Not bad. :lol:
Out on the road it gets about 20 on a mix of premium and race gas. As long as I keep out of the thottle when pulling hills, I can run pump gas, but I'm not very good at keeping my foot out of it. :roll:
Not going to vote, cause I haven't done a quantitative mileage computation for a couple years.
CJ
PostPosted: Tue Oct 11, 2011 11:41 am
22-26 hwy MPG on my fast Darts (64 is NA motor, mid 14s in 1/4, 68 is turbo, high 14s in 1/4 so far). Both are EFI with OD trannies (64 is 5spd, 68 is OD auto w/LU).
PostPosted: Sat Oct 15, 2011 12:28 pm
I have been driving my 73 Dart about 150 miles a day, 5 days a week for the last month. I averaged out my mileage and I'm getting right at 19 mpg.
225, super six
Rebuilt with ported head
Comp Cams 264
Headers, 2.25" single exhaust with a Flowmaster 40
Distributor recurve
2.76 Rear gears
Rebuilt 904
PostPosted: Sat Oct 15, 2011 4:40 pm
6 Pack Dart
My 63 Dart gets 19.44 on the freeway with 3.80's in the rear end and it did a 90.25 MPH in 14.95 sec at Redding (1/4 mile).
Richard
PostPosted: Sun Oct 16, 2011 9:16 am
I get on average 19mpg with my 80 dodge d150. It is a bone stock / with a833od, running 235 75 15 tires. average speed 50-60mph running e10 fuel
This is my hooptie, there are many like it but this one is mine. With out my hooptie I am walking and without me my hooptie is broken down.
1980 dodge d150, sl6, 4sp od, air
PostPosted: Sun Oct 16, 2011 1:58 pm
I didn't even vote cuz mine isn't up there. Checked it yesterday after putting 200 miles on my tank, avg, 12mpg. Only mods are a 2.5" exhaust and hei ignition. The throttle bushings leak though and I drive up a big hill every day to work. No OD either. I've gotten anywhere from 11-19 mpg in my truck depending on how well it's running.
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
 Post subject: Gas Mileage
PostPosted: Wed Oct 26, 2011 1:39 pm
Car Model: 1983 d150 a833 vin m
Since the speedometer and odometer is off by 20 % due to the replacement rear end- after correcting for the errors I get around 17.5 mpg in town driving around 30-40 mph and trips of 5-20 miles.Thats running 75w90 in the A 833,235/75r15 and mineral 10w30.Air temp between 45 and 70 Carter bbd from a 318 with the choke disconnected and a stock 74 electronic distributor at 6 degrees of timing and GM HEI .On the one and only road trip it got somewhere around 24 mpg in the lower portion of NM/west Texas in 100 degree heat.
http://www.facebook.com/photo.php?fbid= ... =1&theater
I may be slow,but I"m ahead of you.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 8 guests
