It is currently Tue May 12, 2026 12:22 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Thu Oct 27, 2011 1:54 am
Thank you Charlie, I stand corrected. I thought the timing dots lined up at #1TDC on the compression stroke. If the dots line up at TDC on the exhaust stroke, then Slanty 6 is doing everything right. My sincerest apologies for giving incorrect information.
PostPosted: Thu Oct 27, 2011 5:57 am
No problem. It would seem logical to have the sprockets line up dot to dot, at #1 TDC compression, but that is not the case. The first time I tried to degree a slant cam, I was confused, and thought the sprockets were mismarked, but that is just how it is done.
PostPosted: Thu Oct 27, 2011 7:12 am
I just learned something new too! I always thought the same thing Reed did.
Thanks Charlie! :D
PostPosted: Thu Oct 27, 2011 11:10 pm
:shock: OK, good I'm not crazy. (somebody tell my wife that ).Thank you Charlie for clarifying this for me. I truly appreciate it.
PostPosted: Thu Oct 27, 2011 11:42 pm
I found TDC—it was behind the sofa all along!
PostPosted: Fri Oct 28, 2011 8:07 pm
Please!...we live in Western Canada now.....say Chesterfield!
PostPosted: Sat Oct 29, 2011 7:25 am
Sandy:
Remember Dan is Canadian on paper, not natural born, hence most likely the lingo slip.
In Maine we say; just because the cat has kittens in the oven don’t make them muffins.
I offer an international lingo compromise: Davenport.
A little burning question of one that parks endlessly on a Davenport: would he be called a Chesterfield Potato?
That kind’ah grates on one ear, there ah?
LOL
PostPosted: Sat Oct 29, 2011 10:03 am
I found TDC—it was behind the Marlboro all along!
PostPosted: Sat Oct 29, 2011 3:12 pm
Line up the dots, and see if you can make to the bed before you stumble and fall... Make sure you have a plastic trash can nearby. Cams are for sissy's anyway, I use F1 spec pneumatic valve actuation with computer control!!
PostPosted: Sat Oct 29, 2011 4:41 pm
............we call them.....teenagers.
PostPosted: Wed Nov 02, 2011 12:20 am
Allright boys, swinging this a bit more on track now I got a few more questions.
1) Shouldn't there be an oil slinger disk somewhere between the crank snout and sprocket/ timing chain cover ? I could be thinking of one of the industrial engines at work so please excuse me..
2) Do I need to drop oil pan slightly to get the "wedges" of the timing chain cover bottom gasket in ? Or just the bolts that I removed to get the cover out ?
3) Use regular pipe "dope" on one timing chain cover mounting bolt that threads into a coolant passage way ?
PostPosted: Wed Nov 02, 2011 9:31 am
Possibly. Some got them, some didn't.
Yes and no. You are supposed to drop the pan a bit to get wedges seated. However, I leave the pan in place, put a bit of RTV sealant in each corner, and force the timing chain cover in place. It works for me.
Not necessary. If you want, run a tap through the threads and run the bolts through a die to clean up the threads, but no sealant or putty is necessary.
