It is currently Mon Oct 26, 2026 8:04 am
 Post subject: super six questions.
PostPosted: Sun Nov 06, 2011 1:32 am
I have a few questions regarding the super six.
The 2.25" exhaust system, is that inside or outside diameter?
Anyone who've ported the outlet of the exhaust manifold, how much of a difference did you notice in performance and economy?
Can I get any 2.25" pipe, two stud exhaust flange?
I own a welder....why pay for labor!!! :!:
Has anyone pieced together their own 2.25" exhaust system from pre-bent tubing purchased from either a parts store (such as Napa)/and or a custom shop? :?:
I thought I had one more 'Q but to tired to even think so any help and feedback is appreciated...I have not done an exhaust system before.
I already installed the intake/exhaust manifold, no gasket sealer...would anyone recommend using it?
'73 Scamp (the girlfriend): 225ci super/6 2BBL conversion (Almost done!)
'90 Subaru, wagon (the wife): H4-cyl 2.2L
1977 Mercedes-Benz 300D, 5cyl diesel(For sale!)
PostPosted: Sun Nov 06, 2011 4:58 am
if you have a welder order 180deg bends and straight pipe , cut the bends you need . smoothing all the joins inside that you can doesn`t hurt.
PostPosted: Sun Nov 06, 2011 5:22 am
On the intake/exhaust manifold heat box junction, either get a Remflex or Aussie graphite gasket or cover the metal gasket with orange high temp sealant on both sides, wait 30 minutes, and then assemble it. You may not have a leak when it's done.
If I were you I would just get one of these.[/url]
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sun Nov 06, 2011 8:51 am
PostPosted: Sun Nov 06, 2011 12:37 pm
Hi exoJjL, here is a tip from an earlier thread:
Super Six Exhaust Manifold Question.
Olaf.
Aspenized
PostPosted: Sun Nov 06, 2011 12:52 pm
AHHHH!! Already got the intake/exhaust on the head with the fel-pro gaskets (no sealer) I figured it would work alright since it's a metal gasket.
PostPosted: Sun Nov 06, 2011 3:28 pm
Inside diameter.
Nope, exhaust pipe measurements are OD (outside diameter)
PostPosted: Sun Nov 06, 2011 4:18 pm
yup, found this from another thread.
http://home.comcast.net/~armstrong225/FDex5.jpg
PostPosted: Sun Nov 06, 2011 4:20 pm
Anyone know the difference between these two carburetor gaskets for the Carter BBD?
PostPosted: Sun Nov 06, 2011 5:09 pm
The one with the two holes is better. The other looks like it was made for an open plenum manifold (maybe a jeep application?).
82 D150-225/727
PostPosted: Sun Nov 06, 2011 6:14 pm
If you go to the engine FAQ's Carburetor operation & repair information, there is important reading regarding that gasket from page 26->on in the BBD_Manuals.pdf.
If you're planning to make a heat shield, you need both anyway; one below, and one on top of the shield.
Olaf
BTW, the manual is 7.4Mb and free to download for keeping a copy for later.
Aspenized
 Post subject: Header pipe
PostPosted: Mon Nov 07, 2011 8:50 am
If you're looking for a pre-bent pipe, do a search for Accurate Exhaust products. I got my header pipe from them. It was good stuff, albeit probably a more expensive way to go then crafting your own.
 Post subject: Re: Header pipe
PostPosted: Tue Nov 08, 2011 2:43 pm
Just got this from that site:
Flange, LP 2 1/4 inch
Part Number ACC-109
http://www.accurateltd.com/Flange-LP-2- ... p_145.html
I should be able to run this for the tailpipe:
http://www.accurateltd.com/Over-Axle-Re ... p_205.html
 Post subject: Accurate
PostPosted: Fri Nov 11, 2011 3:33 pm
Yep, that should work.
PostPosted: Fri Nov 11, 2011 3:59 pm
Anyone ever run a cherry bomb as a resonator on the tailpipe while using a new stock type muffler? Just wondering anybodies opinion.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 10 guests
