It is currently Tue May 19, 2026 2:44 pm
 Post subject: damper install
PostPosted: Tue Oct 25, 2011 6:13 pm
Just recieved my ausi made balancer and looks good. Wondering what the easiest way to install, do you heat them up or do I need to buy a longer bolt then what I already have and find a way to lock the motor?
PostPosted: Tue Oct 25, 2011 6:37 pm
Don't heat it up! :shock:
Installation is by means of an appropriate bolt. An air wrench makes the quickest installation, though a strap wrench can be used if you need to lock the engine.
PostPosted: Tue Oct 25, 2011 8:03 pm
6 Pack Dart
Buy or borrow
http://www.jegs.com/webapp/wcs/stores/s ... ation+tool
Richard
PostPosted: Tue Oct 25, 2011 8:20 pm
I've heated up Chevy ones with a propane torch for a min and went on with a few decent taps. But I'm sure its not good for the rubber. I'll just buy a longer bolt and I didn't even think of using my big impact. Thanks
Contributor
Longer bolts and large washers of the proper size are often found on Mopar V8's. I keep one just for installing dampers.
PostPosted: Tue Oct 25, 2011 9:23 pm
6 Pack Dart
This would be the cheap and very workable way.
Richard
PostPosted: Tue Oct 25, 2011 9:49 pm
I noticed that this damper has 2 marks, one lines up with 0 and another about 1 o clock what's the 1 oclock position for?
PostPosted: Tue Oct 25, 2011 10:52 pm
6 Pack Dart
Some early engines had timing tab on drivers side (bolted to timing cover).
Richard
PostPosted: Tue Oct 25, 2011 11:30 pm
Is this other mark a full mark front to back or is it just on part of the damper?
PostPosted: Wed Oct 26, 2011 7:53 pm
both marks, are only on the back half of the belt groove. (closer to engine) nothing at all on the front half
PostPosted: Mon Nov 14, 2011 3:12 pm
I finally got my air compressor back home from using it texturing ceilings and walls for a house I've been working on. Anyways, I got the bolt and washer. I oiled up the damper in side and out, but it seems to be quite a tight fit. It started folding the washer and now it seemed like its gauling the threads a little. And with the impact, its actually spinning the entire crank. I don't think its butted down all the way. There is about a 1/4 between bracket and back of damper
PostPosted: Mon Nov 14, 2011 4:53 pm
That is why you need a harmonic balancer installer. Go to your local auto parts store and rent one. It will save you a lot of hassle, and the threads in your crank snout will thank you.
Also, the problem with heating things up to install them is that they are a PITA to get back off. I found out the hard way with crank sprocket on my truck.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Mon Nov 14, 2011 5:28 pm
What's the part number for a decent installer
PostPosted: Mon Nov 14, 2011 5:36 pm
Just go to an autoparts store and ask for a harmonic balancer installer. No part number to it.
Most of your major chain brands (except NAPA) have a tool rental program.
82 D150-225/727
PostPosted: Mon Nov 14, 2011 5:43 pm
Rather buy my own
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 5 guests
