It is currently Fri Jun 19, 2026 7:24 am
 Post subject: Is This True?
PostPosted: Tue Nov 15, 2011 5:09 pm
Another tip for the people that are looking for a way to convert the 4 inch bolt pattern on the front wheels to the 4-1/2" without changing out everything. This applies to drum brake cars only. Look for a drum brake AMC Gremlin. The bolt pattern is 4-1/2" and the bearings and hub will fit perfectly on the A-body spindle. Surprise, Surprise!....
Bob Doty off of Houston Mopar Car Club website.
I live near a salvage yard with alot of Gremlin's(AMC Cars),is this drum/hub swap real?
1964 Dart GT
PostPosted: Tue Nov 15, 2011 5:40 pm
It would be interesting if it was. Please post what you find out.
PostPosted: Tue Nov 15, 2011 5:52 pm
I have also heard that early Mustang will work, but I have never seen any proof of it.
Run down to the yard and grab a pair of drums/hubs. They can't be asking a whole lot of cash for them.
PostPosted: Tue Nov 15, 2011 8:54 pm
The Mustang thing applies to KH disc brakes fer sher.
PostPosted: Tue Nov 15, 2011 8:59 pm
couldn't you check for a parts number interchange at your local store? (bearings, and whatnot) my guys are pretty cool, might save you the time, money and effort... let me know.
Matt
63 Valiant 200
64 Dart 270
73 Fury II
84 Cherokee 2 dr
86 Dodge W-150
73 Volvo 144
74 Volvo 145
81 Volvo 245
PostPosted: Wed Nov 16, 2011 6:20 am
Car Model: '23 T-bucket
One can check part numbers all they want. They both might use the same front wheel bearings. The problem may be that there's a difference between the distance(s) between the two bearings, and there may also be a difference in depth or offset of the drum to the hub. The only real way to find out is to try it.
Roger
PostPosted: Wed Nov 16, 2011 7:24 am
Roger, good point.
Matt
63 Valiant 200
64 Dart 270
73 Fury II
84 Cherokee 2 dr
86 Dodge W-150
73 Volvo 144
74 Volvo 145
81 Volvo 245
PostPosted: Wed Nov 16, 2011 8:24 am
The AMC hubs use the same wheel bearings as the '72 and earlier A-body 10" drum brake spindle, but the seal is different. If you have 9" drums you're out of luck. I was going to put AMC hubs on my Barracuda, but ended up changing spindles.
PostPosted: Wed Nov 16, 2011 10:02 am
I have a 64 Dart with 9" drums :cry: , guess I will update the bolt pattern in some differant way...Future Project.(Discs?)
1964 Dart GT
PostPosted: Wed Nov 16, 2011 2:01 pm
i'm in the same boat i guess? I got 4" pattern in the rear and 4.5" pattern in the front... :? :x :? :evil: :x :?
Have you heard of wheel adapters?
'73 Scamp (the girlfriend): 225ci super/6 2BBL conversion (Almost done!)
'90 Subaru, wagon (the wife): H4-cyl 2.2L
1977 Mercedes-Benz 300D, 5cyl diesel(For sale!)
PostPosted: Wed Nov 16, 2011 5:19 pm
yeah,those things have always looked like a bad idea.
1964 Dart GT
PostPosted: Wed Nov 16, 2011 5:35 pm
Isn't there a rear axle or complete rear end that's a straight swap into early A's?(with 4.5"bolt pattern)
1964 Dart GT
PostPosted: Wed Nov 16, 2011 7:42 pm
Online
The wheel adapters (billet, hub centric) you have pictured are completely safe IMHO. I have run those on road courses and dragstrips on my Valiant racecar, and recently on my '68 turbo Dart. Cameron Tilley has been running that type on his 630 HP turbo Valiant for years.
However, if you kill yourself with them, I disclaim responsibility since I cannot be there to help you shop for them or install them or...
PostPosted: Wed Nov 16, 2011 11:26 pm
Almost. I guess the early 70's ford mavericks and Mercury comets swap in.
http://www.slantsix.org/forum/viewtopic ... end#326418
PostPosted: Thu Nov 17, 2011 3:50 am
73-76 A Body 8.25 LBP rear is a direct bolt-in. Use the shock plates that come with the 8.25 rear
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
