It is currently Wed May 27, 2026 6:06 pm
 Post subject: Pinion angle?
PostPosted: Mon Nov 28, 2011 11:31 am
http://slantsix.org/forum/viewtopic.php ... &start=240
Please check my numbers in the above post, Thanks, Rick
PostPosted: Mon Nov 28, 2011 6:57 pm
Rick pinion angle is the difference between the angle of the transmission and the angle of the pinion yoke. Driveshaft angle has nothing to do with it.
Put your angle finder on the flat of the yoke with it level, and get your trans number off the pan if you have to.
 Post subject: ?
PostPosted: Mon Nov 28, 2011 8:01 pm
Every time I do this I get confused. The MP Chassis manual says to measure the driveshaft angle and then the angle at the yoke relative to the ground to get the correct "rear universal joint angle" What am I missing here? I thought I had it all ready to go!! I be stupid!! :lol: :lol:
Thanks for your patience!
Rick
PostPosted: Mon Nov 28, 2011 8:31 pm
Every winter there are as many "pinion angle" threads on Moparts as there are aluminum head threads here. :lol:
Anywho, here's a link to one of the less volatile ones that actually has some really good info in it.
http://board.moparts.org/ubbthreads/sho ... ost6345762
 Post subject: Thanks
PostPosted: Tue Nov 29, 2011 5:04 am
I'll pull the driveline out and check it the way in that article. :?
Buy the way, My 4 valve aluminum head works great! :lol: :lol:
Rick
PostPosted: Tue Nov 29, 2011 5:52 am
:lol: :lol: :lol: :lol: :lol:
 Post subject: Angles
PostPosted: Tue Nov 29, 2011 8:05 am
Ok Big D. Guidance appreciated! :lol: I pulled the driveline and here are my readings.
Off of transmission dust boot 4 degrees down
Off of rear yoke 2 degrees down
Sooo! if I understand (which I probably don't) In an ideal world I would want the rear at the opposite angle 4 degrees up, so the two offset each other.
Then to allow for wind-up I need 3-4 degees down from the tranny reading.
That would mean my rear yoke needs to be at 0 degrees to have 4 degrees difference?
Right now I am at 6 degrees, and am not changing until I here from you!
:lol:
One other thing is that my car is a stock leaf spring car & automatic. It will be a 4 speed before it is all over. That article does not mention a stock leaf spring reading. Maybe my 6 degrees is OK??
Thanks a million,
Rick
PS Zilla, I'll send you one of them Aluminum heads as a thanks! :lol:
PostPosted: Tue Nov 29, 2011 9:13 am
If it were me, I'd put the rear at 0 and call it a day.
I'll take your aluminum head and CAD it, then start casting copies down at my shop. I can melt down Jaguar blocks I get from the junkyard down the road and make a fortune. :D :D :D
 Post subject: Wow
PostPosted: Tue Nov 29, 2011 9:34 am
You mean I actually understood it!!! :lol: Miracles do happen. But they don't last long! Next week I probably won't remember!
I only cast 30 of the aluminum heads, but yours is on the way. I am having trouble getting the direct cylinder injection to work right with the twin turbos. Maybe you can help.
Thanks Slantzilla!
Rick
PostPosted: Tue Nov 29, 2011 10:05 am
You know I was setting them up for nitrous, but EFI ports are an easy switch. :lol:
 Post subject: Zeroed!
PostPosted: Tue Nov 29, 2011 12:21 pm
Put her at zero at spiked her fast. Moving on
Rick
