It is currently Sun Oct 11, 2026 1:17 pm
PostPosted: Wed Dec 14, 2011 2:49 pm
Okay, I know that Clifford Performance does not have a great reputation here. However, there is a carb adapter on their website (part number 08-1013) that is for using a 2bbl Holley or Weber on one of their 4bbl intakes. This adapter looks similar to the Mr Gasket carb adapter, but where the carb bolts onto looks like it is much closer to the Weber pattern. Does anyone here have this adapter, or has anyone here seen it? The price isn't too bad, and the hacked up Mr Gasket adapter that I'm using leaves something to be desired.
Thanks! :)
'78 Volare 225
'67 Charger 318
PostPosted: Wed Dec 14, 2011 2:57 pm
Wes, I have 2 Holley 2bbl plates for the Clifford, but I'm not sure of the part number. I'll be at the shop this weekend and can look.
PostPosted: Wed Dec 14, 2011 5:29 pm
Okay Dennis, thanks! 8)
'78 Volare 225
'67 Charger 318
PostPosted: Wed Dec 14, 2011 7:19 pm
Gents,
Are the inner four manifold bolts the same spacing as a Offenhauser? I have an Weiand/Offenhauser with out the 4 barrel or 2 barrel plates. It would sure be nice to have them so I can use the manifold.
Thanks,
PostPosted: Wed Dec 14, 2011 7:33 pm
Ted, IIRC, they are not the same. It isn't that big of a deal to drill a regular 4 hole carb spacer plate to fit though. :D
PostPosted: Wed Dec 14, 2011 7:34 pm
Are these generally aluminum 1/2" plate stock?
PostPosted: Thu Dec 15, 2011 3:01 am
Yes.
PostPosted: Thu Dec 15, 2011 8:51 pm
I have a Qcad file for making an adapter for the Offenhauser. If you are interested, it supposedly has an interchange format. Not sure what it interchanges with thou.
PostPosted: Fri Dec 16, 2011 6:46 am
I would be very interested in seeing that, but I don't have QCAD on my computer.
'78 Volare 225
'67 Charger 318
PostPosted: Fri Dec 16, 2011 7:24 am
Thanks! :)
Clifford parts are (for the most part) OK; it's their customer service and shipping that has the bad reputation. A lot of the Clifford intakes have a removable carb plate, so their 2 barrel adapter doesn't have the same sort of transition an adapter meant for a 4 barrel flange sometimes has.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Fri Dec 16, 2011 8:21 pm
It's free on Linux. A simple apt-get on Debian.
Users browsing this forum: Google [Bot] and 19 guests
