It is currently Sun Oct 11, 2026 7:23 am
PostPosted: Thu Jan 05, 2012 6:29 pm
If it ain't one problem its another..... Got the car home and it just dies. After lots of checking and testing, more checking.... The motor turns, but the distributor doesn't.... OK time for a new gear. But the damned thing won't come out!!! I think the roll pin backed out and is holding the distributor in the block!
Anyone know if an easy way to get it out without tearing the motor down????
PostPosted: Thu Jan 05, 2012 6:46 pm
6 Pack Dart
Try rotating the motor as you or someone else pulls on the distributer. It might be the pin is in the cam gear :idea:
Richard
PostPosted: Thu Jan 05, 2012 7:17 pm
Nah, I can pull the distributor out juuuuuust far enough that I can rotate the shaft if I cock the housing a bit.
Ill see if I can yank like hell on it and shear the pin tomorrow.
PostPosted: Thu Jan 05, 2012 7:58 pm
6 Pack Dart
All of them I have seen are roll pins, it should bend or maybe break if it breaks don't worry about the part that goes into the pan.
Richard
PostPosted: Fri Jan 06, 2012 5:21 pm
GOT IT! I wiggled the hell out of it and that pushed the roll pin in far enough to clear the block. The gear was shredded pretty bad.
No one had a drive gear in stock, so I paid the 60 bucks for a whole new unit that Napa listed for a 76 Duster/Dart. Had my 7 year old bump the ignition for me to get it to TDC, and timed it by ear. She seems to be running way better with this new distributor in! ALLOT snappier! I wonder what advance weights and springs are in it?
PostPosted: Fri Jan 06, 2012 6:22 pm
6 Pack Dart
Did you have to give the old distributer for a core?
Richard
PostPosted: Fri Jan 06, 2012 9:40 pm
There was an 11 dollar core on it, but I figure ill keep it and order a new gear for it. Then keep it in the trunk as a spare.
PostPosted: Fri Jan 06, 2012 11:34 pm
6 Pack Dart
Good plan and you have the original curve (springs) :)
Richard
Users browsing this forum: Google [Bot] and 17 guests
