It is currently Mon Jun 15, 2026 10:57 pm
 Post subject: Head problems
PostPosted: Mon Jan 09, 2012 8:41 pm
Well, I took my head to a shop the other day- big valves, guides, hardened seats etc.
I get a call today, the guy told me to come in and have a look at a problem.
I said:
"give it to me straight"
He tells me that he found a pinhole while machining the valve seat. He seems to think it is a casting flaw .
Have not seen it yet.
Anyone else ever have this happen?
:evil:
PostPosted: Mon Jan 09, 2012 8:46 pm
how big are the valves? what year is the head? usually there is a problem when grinding ports and pocket areas. if it`s in the wall you might be able to weld it.
PostPosted: Mon Jan 09, 2012 8:53 pm
Exhaust valve 1.44".
I think the head is from a'66 or '68 but not positive
He said it was in the actual machined area for the valve seat meaning it revealed itself in his cut out area.
Keeping my fingers crossed that it will be repairable.
PostPosted: Tue Jan 10, 2012 6:06 am
if it the seat that is a hard area to weld, i was told the weld will be harder than the head surface and the seat cutter wouldn`t be able to cut the seat ture. maybe a harden seat might be installed.
