It is currently Mon Nov 30, 2026 2:27 am
PostPosted: Thu Jan 26, 2012 8:23 am
OK
made in U.S.A.
QUCIKTIME
custom design "special purchase"
12 bellhousings @ $650 each plus shipping
they want dept/imputshaft spects.
stated mopar is 7.4-7.5 ?
degree shift for the T5 mount
15 degrees to the drivers side?
talked this morning to them.
3-4 week delivery
slant six's RULE!
http://www.usajon.com
PostPosted: Thu Jan 26, 2012 2:44 pm
I wonder if they'd do a 4L60E bell? 12 bells up front is a tall order.
PostPosted: Thu Jan 26, 2012 3:03 pm
I thought they were already doing a Slant/T-5 bell?
PostPosted: Thu Jan 26, 2012 7:45 pm
1 @a time is $850
slant six's RULE!
PostPosted: Fri Jan 27, 2012 6:18 am
Thanks for the further info, Jon. Yeah, I thought Josh and others bought these for a T5 already...
PostPosted: Fri Jan 27, 2012 10:47 am
Lou,
I bought my Quicktime bellhousing for the A833.
PostPosted: Fri Jan 27, 2012 3:23 pm
Lou,
http://www.summitracing.com/parts/QTI-RM-7072/
slant six's RULE!
PostPosted: Fri Jan 27, 2012 6:29 pm
Who'da thunk it! :shock:
 Post subject: modular
PostPosted: Sat Jan 28, 2012 6:51 am
I thought the whole deal with Quicktime was that they were to be "Modular"? That they could easily add a different adapter plate? T-5 plate should be a piece of cake to add? Just guessing.
I'm glad they built this, but in my opinion there would have been a bigger market for it if they would have opened it up to the 10 1/2" small block size. then the clutch/ pressure plate and flywheel availability is wide open. Our selection of Slant six "performance" clutches is pretty limited and still leaves a lot to be desired. Just my opinion.
Rick
PostPosted: Sat Jan 28, 2012 9:15 am
It almost looks like that has a T5 pattern and some adapter rings already??
PostPosted: Sat Jan 28, 2012 2:40 pm
Car Model: Toad Wagon
They are modular, to an extent.
The adapter rings supplied with my kit are for the two nose sizes of Chrysler's gearboxes.
What size (and length) is the T5 nose?
I believe the holes present are for Chrysler boxes as well.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Sat Jan 28, 2012 2:47 pm
HOLY SWEET MOPAR crapsicles !!!!! $650 ??!!!!!!! Its a banging bell and if money was no option lol, but I think I will be happy making an adapter plate for my '97 "long shaft" T5
-Mike
PostPosted: Sat Jan 28, 2012 6:24 pm
-Mike
Mike, it is not just a bell. It is a SFI rated scatter shield housing. Some types of racing require it. Granted it is not cheap, but?????
PostPosted: Sun Jan 29, 2012 7:59 am
-Mike
Hard enough launch on a stock clutch and motor can be a gamble without a shield.
Users browsing this forum: Amazon [Bot] and 1 guest
