It is currently Wed May 13, 2026 11:11 pm
PostPosted: Thu Feb 02, 2012 7:13 pm
say if one were to have a later car, with a big hole converter. and one picked up an engine with a small hole crank, would one be able to switch out the converter to a small hole, with out any problems?
also is there a picture anywhere for side by side comparison?
PostPosted: Thu Feb 02, 2012 7:16 pm
6 Pack Dart
No the input shaft is smaller in diameter :(
Richard
PostPosted: Thu Feb 02, 2012 7:30 pm
wtf was dodge thinkin, ohwell thanks!
PostPosted: Thu Feb 02, 2012 7:42 pm
6 Pack Dart
My 63 Dart has the small hole early crank and the transmission has a smaller diameter input shaft. The later large hole crank transmissions had larger input shafts.
Richard
PostPosted: Thu Feb 02, 2012 8:13 pm
You can have a converter built to fit the small hole crank and the large input shaft trans. I have all of my converters were made that way.
PostPosted: Thu Feb 02, 2012 8:21 pm
well a fellow member needs a crankshaft, and he is having hard time finding one local for the right price i guess, but all i have is a small hole crank, but also have the matching converter. but i guess it doesn't matter lol (he has late car)
PostPosted: Mon Feb 20, 2012 11:48 am
I'm having a similar problem and I'm looking into having my crankshaft machined out larger to match up with my torque converter.
Van - PDX
69 A108 8 door panel, 225 super/6 - auto 727
84 V65 Honda Sabre
86 Yamaha TT 650
Good-Fast-Cheap
Pick any two
PostPosted: Mon Feb 20, 2012 12:12 pm
If your crank is out, this is a good idea. Doc has done this with success. I've never tried it, but it should work.
