It is currently Thu Apr 23, 2026 4:05 am
 Post subject: Raybestos Master
PostPosted: Sun Oct 05, 2003 7:52 pm
Last time I trust one of those... on my way to the show, on the freeway everythings dandy, apply brakes... apply brakes... finally the third time the pedal doesn't sink and I get some braking action. This is on a lifetime guarente raybestos master kragen special. Hmmmm, is it a coincidence this master is listed for $64 with a lifetime while bendix is $94 for only a 1 year?
Strange, why is the power drum and non power drum master, in raybestos brand, listed under the same part # MC36338 ?
PostPosted: Mon Oct 06, 2003 5:39 am
Sounds like you are using the cast iron master cyl still. It is almost impossible to get a good core for them now days. That is why remans dont last. The only way to reman 1 and have it last is to sleeve it. Look around for someone that puts a sleeve in them . It is way more expensive but works.
Or just swap to the later model aluminum master cyl.
________
Suzuki splash specifications
________
Wiki vaporizer
PostPosted: Mon Oct 06, 2003 11:11 am
Your right it is cast iron, but I thought the Lifetime Guarentee ones were new? Hmm...
Don't you need an adapter plate for the aluminum ones? If I want an aluminum one for an all drum car what car do I ask for? Can I use the same rod?
 Post subject: New Only!
PostPosted: Mon Oct 06, 2003 6:58 pm
Pierre,
I put 2 lifetime ones on from Advance auto. $36 bucks if memory serves me correct. Neither one worked well at all! After going back with the second one for replacement, I got a "new" one for 65 or $68. It was the best money I ever spent. Rebuilt ones are junk. That came from a man who worked at Advance and told me that 4 out of 5 come back within just a few months!
Rick
PostPosted: Mon Oct 06, 2003 7:32 pm
This one was $76 on the reciept. Granted its been in there for maybe 5 years but aren't these things supposed to last lots longer then that?
The counter guy did say it was new when I bought it, but I don't have proof that it is new, for that matter I don't have proof it was rebuilt, either.
I think I may just hold off and go directly to disc.
PostPosted: Tue Oct 07, 2003 1:19 pm
"Lifetime" in the parts biz means 5 years. That is the average that anybody owns a used car. By the time 5 years is up, you will have either lost the receipt or sold the car. Also a "Life Time" warranty usually is not transferable to a new owner.
